Duet Wifi have Analog I/O?
Are there analog inputs and/or outputs available on the board? Where can they be found?
The Z probe input is analog, along with the thermistor inputs. I'm not sure if you can repurpose them for anything though.
@nhof Thanks for the info, I will look into it more.
@jpomo10 output or input? We approximate analog output with PWM, analog input as @nhof says are temperature inputs and the zprobe input
