G30 / G28 Bad Command
there seems to be a problem with the deploy and retract script.
can you execute the command manually in the console and check for extra characters in the script.
Yes, all work fine. Pin Down, Pin Up, Selfe Test ON and OFF.
also the Z Probe value (1000) is displayed in the test
what is the size in bytes of the deploy and retract script
here the whole content of the files
Deploy:
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Sep 26 2019 16:26:18 GMT+0200 (Mitteleuropäische Sommerzeit) M280 P3 S10 I1
Retract:
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Sep 26 2019 16:26:18 GMT+0200 (Mitteleuropäische Sommerzeit) M280 P3 S90 I1
@Veti said in G30 / G28 Bad Command:
200 Bytes Deploy
202 Bytes Retract -
can you issue the commands M401 and M402?
Yes, Pin is moving out and in.
But:
16:49:18M402
Error: Bad command:
16:49:11M401
Error: Bad command: -
there is something wrong with your deploy and retract scripts.
delete everything and type the commands per hand
delete everything and type the commands per handnow this happend.
if i type M280 P3 S10 I1 it works. But M401 not
this is my library
Delete the probe files and create new ones with just the M280 command,
Perhaps there is something in the existing file that is causing the problem.
Same problem
M401
Error: Bad command: M280 P3 S10 I1Their is only the M280 command in the file.
Okay. now it works fine.
I deleted all again and created again. Thank you very much!!
