Solved CR-10S Dual Z Config
what is not working? is only one stepper moving?
Yes, its not moving in sync. when i move my Z only one of the Z stepper is turning smoothly. and the other is moving as if its forced to.
check each cable to the z motor that is not moving correctly with a multimeter.
there could be bad crimps.
check that the phases are connected correcly -
i did try to switch between the 2 on my board.
Prev, Right side Z stepper is on Z Drive 2( Z stepper slot) its moving smoothly.
Then, i switch Right side Z stepper (Drive 2) placement with the other Z stepper. and now its the other way around. the left one turn smoothly while the right one does not. so im pretty sure that my Cables are fine. Is there anything i have to add to my config aside from the ones that i have posted to make this work? -
did you observe the correct order of the commands.
see
https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
Order dependenceM584 must come earlier in config.g than any M350 and M906 commands. If it creates new axes, it must also be earlier than any M92, M201, M203, M208, M350, M566, M574 , M667 and M669 commands.
i just knew about the thing you send me but unfortunately. my current config is in the right order for that part.
M569 P0 S0 ; Drive 0 (X) goes backwards
M569 P1 S0 ; Drive 1 (Y) goes backwards
M569 P2 S1 ; Drive 2 (Z1) goes forwards
M569 P3 S1 ; Drive 3 (E) goes forwards
M569 P4 S1 ; Drive 4 (Z2) goes forwards
M584 X0 Y1 Z2:4 E3 ; Driver 0=X, 1=Y, 2+4=Z, 3=E
M92 X100.00 Y100.00 Z400.00 E415.00:400.00 ; set steps per mm
M566 X900.00 Y900.00 Z24.00 E300.00:24.00 ; set maximum instantaneous speed changes (mm/min)
M203 X60000.00 Y60000.00 Z6000.00 E1500.00:6000.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z100.00 E10000.00:100.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E650:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout -
As a test create a config.g file that uses this command and change everything else as needed
M584 X0 Y1 Z2:3 E4
Guys, Thanks alot for the reply and help. i really appreciate it. I have fixed my issue. it was a stupid mistake on my part i did not reinstall the black jumpers on the extra open Z slot on my duet. once i installed it back. everything went smoothly.
@Kaizer said in CR-10S Dual Z Config:
M906 X800 Y800 Z800 E650:800 I30 ; set motor currents (mA) and motor idle factor in per centyou might also want to clean up the second e settings, as you only have one e driver now
