Solved BondTech CR-10S Extrusion Problem
I just finished upgrading my CR-10S with Duet 2 wifi. Tried to do 1st print and failed miserably.
When its printing, i cant see any filament being extruded. the gears are moving but nothing, and i also hear clicking sound from my extruder. Im so confused on what is going on. Esteps calibration using G1 E100 F100 works well. Using the extude button from the web-interface also works well. Checked the flow when calibrating Estep and i can see its not clogging. Infact its so smooth. It only happens when i try to print something. Im using PrusaSlicer with RepRap as the G-code flavor. Can anyone help me fix this? My extruder are working fine if its not printing. FYI : tried Simplify3d too. same issue. -
post your config. what temperature are you printing at?
M569 P0 S0 ; physical drive 0 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2:3 E4 ; set drive mapping
M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
M92 X100.00 Y100.00 Z400.00:400.00 E415.00 ; set steps per mm
M566 X900.00 Y900.00 Z24.00:24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000 Y12000 Z2000.00:2000.00 E6000.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00:100.00: E10000.00 ; set accelerations (mm/s^2)
M906 X750 Y750 Z750:750 E650 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; set active high endstops; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F420 T6000 A3 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X32 Y-2 Z5.19 ; set Z probe trigger value, offset and trigger height
M557 X32:300 Y10:300 S134 ; define mesh grid; Heaters
M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Print Temp is the same as to when i calibrate Esteps. so i dont think is not hot enough.
M906 X750 Y750 Z750:750 E650 I30 ; set motor currents (mA) and motor idle factor in per centas to why i have 2 Z settings. if i dont do it like this. my extruder wont even move.
@Kaizer I can see why you need to set two Z drivers. You have defined the extruder to use drive 4 in your M584. By default the first extruder (extruder 0) would be drive 3 and the second extruder (extruder 1) would be drive 4. Now in your tool definition you use drive 0. So if you don't define drive 3 as anything, then the firmware reverts to it's default and sets extruder 0 as using drive 3 so your extruder on drive 4 would become extruder 1. In that case, your tool, definition (M584) should use D1 not D0.
So you have several options. The simplest is to move the extruder to drive 3 and set the Z to only use drive 2. Or, if you really want to use drive 4, define the tool to use D1 not D0.
As for no filament coming out when you print, you probably just need to have a T0 command somewhere to select a tool. Either at the end of your config.g or in the slicer start code.
Do you your slicer set to relative extrusion and 1.75mm filament dia?
@Kaizer said in BondTech CR-10S Extrusion Problem:
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1also you are most likely printing at the wrong temperature. B4138 is the default and most likely wrong for your thermistors.
@deckingman Thanks. It makes a lot of sense now.
My Slicer start Gcode is only
G28 ; home all axes
G1 Z5 F5000 ; lift nozzleshould i add T0 as u said? if yes can u give me an example of the completed code?
@Veti i see, Im actually wondering about it too. but since i dont know much about it. i just leave it as is and do a temperature tower later on.
Im using the stock Bed thermistor for CR-10S and E3D V6 Tube Thermistor for my hotend. i dont know what their names are so idk what to set my thermistor as. if you know, mind sharing it? thanks.
@Kaizer Literally, it's just "TO" on a new line (without the quotes). So:
G28 ; home all axes
T0or put the T0 first if you need to heat the hot end before homing.
@deckingman Thanks alot. will give it a try now.
E3D V6
if its a genuine E3D the settings are: B4725 C7.060000e-8
@Veti Thanks, so its gonna be
M305 P1 T100000 B4725 C7.060000e-8 ; set thermistor + ADC parameters for heater 1
correct. the r parameter is not required as will be replaced by the correct one for your board.
@Veti what do u mean by r parameter? sorry i dont really understand programming language.
R4700. That is optional and not required as its the default value.
@Veti i see, Thanks a lot.
@deckingman Thanks for the help. it works fine now.
@Kaizer Glad you are sorted.
