New setup after errase and wifi antenna switch
Stupid Question but where is the SD Card physically in the DUET or the Panel?
yes the sd card is in the DUET2WIFI
okay, now its:
M502
Warning: Macro file config.g not found.
okso what is the next step to do?
can I do something before checking the board itself, because it's realy hard to get access to it? -
M502 tries to run config.g, rather than outputting it like M503. But it still can't find config.g. Your SD card slot is not working. I don't think there's anything more you can do without removing the Duet and inspecting the soldering and components around it, as @dc42 suggested earlier:
@dc42 said in New setup after errase and wifi antenna switch:
Check the soldering of the pins at the back of the SD card socket to the PCB. Also check that all the resistors in that area are present. Perhaps you disturbed one of those components when you desoldered the WiFi module.
do you see a fail, or do you have a reference picture because I can't find a picture of my board revision?
There's clearly a missing SMD at the upper left corner of the SD card holder, R73
but it is missing over here as well or am I wrong
@eduardschlegel said in New setup after errase and wifi antenna switch:
Check the soldering of the topmost pin in the row of pins on the right hand side of the SD card socket on that photo. You may find it is just resting on top of the PCB pad it should be soldered to. That's the card detect pin.
no, it does look good
I can't tell for sure because that part of the picture is not quite in focus. Thus is the pin I mean:
This line from the M122 report:
SD card 0 not detected, interface speed: 30.0MBytes/sec
indicates that the card detect switch is not working or not connected.
@Nuramori said in New setup after errase and wifi antenna switch:
There are DNP components (including R73) on the board. See the schematic:
https://github.com/T3P3/Duet/blob/master/Duet2/Duet2v1.04/Duet2_1.04c_Schematic.pdf
