Toolchange default tool
Hello
Is there any change that start with out tool?
Now when I turn on printer as default is set tool1.
But i want to start with out tool predefault is that possible?Matej
@matej1006 Please have a look at the G-Code docu:
Key is to understand when and how the tool change macros come into play.
You can put a Tx for whatever tool you want, including T-1 for no tool, near the end of your config.g
awesome thanks
Assuming you turn on the tool changer with no tool loaded, you should not have a T command in config.g. It sounds to me that you have a T-1 command in config.g. I suggest you remove it.
