Missing LED's
Commissioning my Fisher1, duet 0.6 with 1.09 firmware, problem is the X and Z led's are not showing, I have usb socket lit, Y axis LIt which works as instructions (goes out when tripped), and 1 other facing motor loom graphic, all 3 axis motors work, looking for a reason for the missing led's.
Put a connector with a jumper wire on the X and Z connectors and see if you get a LED when that is installed/removed. Or just (very carefully) short the pins with something.
Goal is to separate possible board flaw from possible endstop wiring flaw.
I put a wire across the outside pins of the board connection to replace the connector and the LED lit up.
