My Duet 3 board has arrived
I have no idea at the moment. I need to work with the board on the bench and become comfortable with the new hardware.
For what it is worth, here is a working config.g
It took me longer than it should to understand the new way of doing things. Two concepts to grasp up front:
Pins are now labeled and generally must be explicitly assigned.
Define fans, temperature sensors, heaters, etc first (i.e. assign pins); then 'gather' them into a tool.
There's more... but those two ideas are a huge part of the foundation of transitioning your thinking.
Thanks much.
I don't have my Pi yet and have found the DWC via the Ethernet connection works but is limited.
At least the board is alive and doing something.
@fcwilt For what it's worth, I do have a RPi (plus a Duet 3 main board and 3 prototype expansion boards). But at the moment, I'm running stand alone because I haven't found any compelling reason to do otherwise. I think the advantages of using a SBC are yet to come when people start writing add ons or plugins.
I've also been helping the Duet guys by testing and reporting firmware bugs and fixes with the expansion board firmware, and it has been necessary to cycle the power on numerous occasions. People have told me that killing power is not a kind thing to do to a RPi. So for now, it's fitted but not connected. -
@deckingman said in My Duet 3 board has arrived:
part of the reason i chose to have a dedicated usb supply to the Pi instead of powering it off the Duet, also allows the Pi to control a relay that in turns control the main power for the router.
unexpected powerloss could lead to a corrupt filesystem, but the worst case scenario is "just" to rewrite the image onto the SD card and restoring configuration from backup, still easier to avoid while we wait for an image that is mostly read only to avoid the issue all together.
I would recommend having a Pi attached to the Duet3 as well. File uploads are much much faster (at least if you're dealing with very large files) and the possibilities of running plugins that can directly influence the gcode will be awesome!
As for the new config.g, it does help to have the configuration tool create a full configuration for the printer as reference.
Keep in mind that there are still some limitations within RRF3: https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
@bearer I've actually installed a separate 5V supply for the RPi and with @wilriker's help, I have two ways to shut down the RPi in a controlled manner. The first is via a push button switch which will pull a pin low ( @wilriker has written a tiny script which listens for that event). The second way is via a DSF extension that @wilriker has written. So sending M7722 will also do a controlled shutdown of the RPi. The latter method is intended to be used in conjunction with my UPS. When it senses that the battery voltage has dropped to 21V, a set on contacts on the UPS closes. These contacts are connected to an input pin on the Duet which trigger a macro, which in turn will send M7722 to shutdown the RPi and also do a controlled shutdown of the printer before the batteries expire completely. That's the plan anyway, but at the moment, while I'm still testing firmware, I'm just running stand alone because it's one less thing in the chain (and I still haven't found the time to get my head around the RPi).
@too said in My Duet 3 board has arrived:
For info, there are a couple of other things that aren't on that list. It currently isn't possible to run heater tuning on expansion boards and M581 on expansion boards isn't yet implemented. There are a couple of other things that are a bit "buggy" too but @dc42 is working his way through them.
@Danal said in My Duet 3 board has arrived:
Yes on the Pi, really wouldn't consider running without it. I chose a 4B, primarily because already I had one not committed to anything else. I would run a 3B+ as well. I probably would not bother with anything 'below' that.
I was running it with a 3B (no plus) in the beginning with no issues. Also that one should be considered a minimum as the performance of lower generations will probably not suffice to run DuetSoftwareFramework with the required performance.
I was able to setup a SD card with the DWC files and a very basic config.g file.
I can connect from my browser and interact as I am used to doing.
But I must have something wrong because there are some simple things that don't work.
For example, any attempt to create a file (in directory sys or macros) fails.
Any ideas what might be the cause of that?
@fcwilt No, it works for me - I just tried it. What version of DWC are you using? I'm on DWC 2.0.4.
A word of warning - make sure that "Use CRC checksums for uploads is enabled" (DWC - Settings - Machine Specific). There is currently a problem uploading any files and they can sometimes get scambled. If you get CRC errors, keep trying and after 1, 2 or sometimes 3 attempts, it will work successfully.
Well I copied the iap4e.bin file to the sys directory on the SD card and put the card back into the Duet and now it seems to be working OK.
I'm running a Rpi 3B+ on mine. No issues.
A little Linux experience helps but is not mandatory.
Personally don't see any positive effects of running a Duet 3 in standalone mode, But I'm sure there will be someone along momentarily disputing that though..
the biggest positive (for me) is that it brings wifi to the table - and likely a webcam shortly; but its hard to not argue that its just another thing that can break, so stand alone should statistically be more robust? (and cheaper:)
@bearer said in My Duet 3 board has arrived:
I think it quite easy to argue for an SBC, I also think we can agree that the Rpi SBC is a mature enough technology to be considered sufficiently stable from a hardware point of view.
Also the additional feature set that an SBC brings to the table operating in parallel with the Duet 3 makes standalone operation, only makes sense as a last resort.
On the point of financial economics, I don't think the Duet 3 is aimed at the economy end of the market to the point of where an extra 40.00 or so units of money is going to be a deal breaker.
@CaLviNx said in My Duet 3 board has arrived:
Except that right now, at this point in time, the additional feature set for the RPi is practically non existent. My RPi is fitted and ready to go. But I re-iterate that as of now I don't see any compelling reason for me to "press the switch" as it were. When the firmware is a little more stable, and maybe when the pluggins or add ons start to materialise, then I'll start to use it.
Unless of course someone can give me a compelling reason why I should use it right now. I don't need WiFi and stand alone upload speeds of 1.1MiB/S are more than adequate. What else am I missing out on right now?
I received mine the other day, a ver1.0. Im curious what distinguishes it from ver 0.6
Mines waiting for me at the local sorting office
I think this is (ancient?) history. I use Pi based machines a lot, and I haven't shut one down in the last couple of years. Just punch power. I have never had any issues.
I can't prove this either way... but I've seen a lot of people say it is low to zero risk with current hardware and OS.
