termistors
the config.g
; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Dec 28 2019 00:04:16 GMT+0100 (CET); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M350 X256 Y256 Z256 E256 I0 ; configure microstepping without interpolation
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M208 X220 Y220 Z200 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
@Veti what thermistors does the um2 have?
Is a UM2 +, the termistors have previously worked properly.
I have to make every connector for the Duet, but before the termistors do not work - it has no purpose.
Termistor for hotend and heating bed
What is the resistance of the sensor when disconnected from the board?
What values have you found for the sensors?
From UM2 firmware, it seems they use PT100 instead of regular thermistors, both hotend and bed.
112k
oh sorry - 112 ohm
@minimaxer said in termistors:
oh sorry - 112 ohm
In that case, @aidar is right, they are PT100 sensors, not thermistors. To use them with Duet you need the PT100 daughter board. One board handles two PT100 sensors.
Ok, I read it, the UM2 + has PT100 sensors and I need an extra board -: ((
@minimaxer wasn't able to get back online last night but suspected PT100 as I had the same issue when converting an Up Plus 2 for someone an age ago.
Ok extra cost but the boards mount on Duets (post 0.6 or 0.8.5) with no extra hardware. PT100 are better sensors on many measures, but rely on a well shielded system. That said, if you are converting a machine like the ultimaker then shielding issues are likely already sorted, unless it is broken accidentally in the conversion.
Just keep an eye out for impossible heat changes on the temp plot. In other words if there are sudden changes of 5-10C or more in reported temp in an instant then you have wiring or noise issues.
