Wifi problems on Mac
I try several times and I get the following error after “screen /dev/tty.usbmodem14101 115200”
Warning: Heater 0 appears to be over-powered. If left on at fulwifi reported error: no known network found
wifi module is idle
Any ideas? -
Does M587 report the correct wifi network is setup?
@T3P3Tony
No, give me Failed to retrieve Wifi status -
@Jaime said in Wifi problems on Mac:
@T3P3Tony
No, give me Failed to retrieve Wifi statusSend M552 S0 then try M587 again.
thanks!! was working.
now I´m stock after entry password, I think the problem is the Macpronterface.
any way thanks a lot for your help -
Pronterface will change all commands to capital letters, which could be messing up your SSID password.
Best way to add an SSID is to put the commands into a macro file named ADDSSID.g on the SD card, and then send M98 Paddssid.g to run it.
@Phaedrux hi,
sorry could you please explain me a bit deeper? I don't have experience with macros, and I'm still stock!! -
Here are 3 options:
- Is there a terminal emulator on your Mac? if so, use that instead of Pronterface.
- Use Pronterface, but for every lowercase character in your SSID and password in the M587 command, prefix that character with a single quote character. This will undo the conversion to uppercase that Pronterface performs.
- Move the SD card to a PC, then in the /gcodes folder create a file called SetNetwork.g. In that file, put the M587 command that you want to send. Save it, safely eject it, put it back in the Duet and restart the Duet. Then run M98 P"SetNetwork.g" from Pronterface.
Let me know if the description of how to proceed from DC42 isn't enough and I can provide an example macro that you can fill in your SSID and password and use to add the network.
Hi guys, I still having the same problema using Windows, can´t setup the wifi.
M552 S1
ok
WiFi reported error: no known networks foundthis is what I have
@Jaime Are you working through this guide? https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
It sounds like it's not finding a network that it knows about to connect to.
If you're connected using YAT on a Windows PC, send:
M552 S-1 ; to stop WiFi module
M552 S0 ; to put Wifi into idle mode
M587 ; to get a list of remembered WiFi networksIf your network is not on the list, add it with:
M587 S"your-network-ssid" P"your-network-password"
M587 ; get list of WiFi networks to check it's there
M552 S1 ; to connect to the networkAlso send M115 and post response. There is a bug in RRF 3.0 that doesn't set the password, so update to latest if using RRF 3.
@droftarts Thanks,
yes im working wth this guide, first i started with my Mac now i change to windows10, also i créate a macro with the SSD and pasword but still the same, i´m lost. -
@Jaime Send M115, post response.
Copy paste the log from sending the commands in my previous post, so we can see the responses. Without information, we can't help!
@droftarts , ok
M552 S-1
WiFi module stopped
ok
M552 S0
ok
WiFi module started
M587
Remembered networks:
RED WI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
RED WI-FI DE JAIME CAPLLONCH IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
RÃD´D´E´J´A´I´M ´E´C à IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
Red Wifi de Jaime Capllonch IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok
M552 S1
ok
WiFi module is idle
WiFi module is idle
WiFi reported error: no known networks found -
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
ok -
RED WI
RÃD´D´E´J´A´I´M ´E´C Ã
Red Wifi de Jaime CapllonchThese are all different. What is the real SSID?
@droftarts is a space an acceptable character in RRF for the SSID?
@droftarts
this is the real one
Red Wifi de Jaime Capllonchhow can I delete the others?
@Jaime M588 S"ssid" I think is the correct format?
@Dougal1957
M587 S"Red Wi-FI de Jaime Capllonch"
this supouse to be correct.
