Can duet 2 wifi control arduino board?
Wondering is this setup work?
Can duet 2 wifi control arduino uno/mega/due board?
Via what kind of communication?Like send command to arduino to do things.
The serial port on the PanelDue is probably the easiest, but there is some support for I2C as well. Bear in mind the Duet is 3.3v while most arduino boards are 5v so level conversion may be needed.
There are a lot of threads on here, I'm sure you'll find something relevant if you go looking.
Yes. Via serial, I2C, or simple single logic pins.
As mentioned, be sure you use a 3.3V arduino.
Do you have an example in mind?
