Suddenly all files missing from DWC (Duet3+Rpi)
This has happened twice now. For no apparent reason all of the files are missing on system page. A rotating notice searching for files (or something like that) is displayed. I'm thinking this is a pi issue, but not sure, cycling power restores the files. I'm running a pi4 with a new sandisk 32 gb card and Duet 3 with latest software. Tonight I imaged the card to another sandisk 32gb card, I'll wait and see if it does it again. Anyone else had this happen, solutions?
Next time, see if you can ssh into the Pi. If so:
- ls -al /opt/dsf
- ls -al /opt/dsf/sd
- ls -al /opt/dsf/sd/www
- ls -al /opt/dsf/sd/sys
If those look normal, see below. If they look like files are missing and a reboot brings them back, then you have an SD card problem, or a Unix problem, or similar.
After checking the directories, Depending on how hard you want to research this yourself, you may want to scan the logs. Problem is, I can't really tell you what you are looking for... just anything that looks like an error. Logs are available via:
sudo journalctl -u duetsoftwarecontrolIf dirs and the log look more or less normal, then try:
sudo service duetsoftwarecontrol restartIf that fixes it, there is strong evidence that it is a DSF bug. If not fixed, the question is more open.
And, finally, if none of the above works:
sudo reboot -
Oh, and no, I haven't had files disappear.
I have had a few errors logged, and/or just plain "hang", all of which were resolved by reseating the ribbon cable between the D3 and the Pi.
I'm hoping it's just a flaky sd card, if it does it again I'll do your recommend checks and report back.
$0.02; odds that only /opt/dsf/ is affected by a dodgy SD card sounds slim.
@bearer said in Suddenly all files missing from DWC (Duet3+Rpi):
Completely agree... at the same time, we don't know that was the only effect. I'm assuming that the entire SD card became inaccessible, yet the in-memory duetweb and control processes kept running. It is possible that the first visible effect of that scenario in DWC would be that the tabs that manipulate files in sys, macros, and jobs, would look as though the files were missing. I believe that OP checked sys (implicity), but not the others. Probably DWC was too hung to check anything else.
-and/or-
That the Pi could have been entirely hung, but the in-browser javascript's only visible symptom was the rotating file searcher.
I put the replacement sd card in last night and will run it 24/7, so far so good.
Tonight I was going to run the extruder motor from panel due, I entered the speed and length and hit extrude and got a t1 error. Realizing I had not set tool temperature I tried to set the temp from paneldue but couldn't. I came in to where the pc is and tried to set temperature and couldn't, went to system page where refresh is spinning and the searching for files message is showing. Here is the download recommend from above.
pi@duet3:~ $ ls -al /opt/dsf total 96 drwxr-xr-x 6 pi pi 4096 Nov 5 09:16 . drwxr-xr-x 4 root root 4096 Nov 5 09:16 .. drwxr-xr-x 2 pi pi 73728 Mar 19 12:17 bin drwxr-xr-x 2 pi pi 4096 Mar 19 12:17 conf drwxr-xr-x 5 pi pi 4096 Mar 23 19:24 dwc2 drwxr-xr-x 6 pi pi 4096 Nov 5 09:16 sd pi@duet3:~ $ ls -al /opt/dsf/sd total 24 drwxr-xr-x 6 pi pi 4096 Nov 5 09:16 . drwxr-xr-x 6 pi pi 4096 Nov 5 09:16 .. drwxr-xr-x 2 pi pi 4096 Sep 23 2019 filaments drwxr-xr-x 2 pi pi 4096 Sep 23 2019 gcodes drwxr-xr-x 2 pi pi 4096 Sep 23 2019 macros drwxr-xr-x 2 pi pi 4096 Mar 26 11:04 sys lrwxrwxrwx 1 pi pi 7 Oct 22 03:00 www -> ../dwc2 pi@duet3:~ $ ls -al /opt/dsf/sd/www lrwxrwxrwx 1 pi pi 7 Oct 22 03:00 /opt/dsf/sd/www -> ../dwc2 pi@duet3:~ $ ls -al /opt/dsf/sd/sys total 1480 drwxr-xr-x 2 pi pi 4096 Mar 26 11:04 . drwxr-xr-x 6 pi pi 4096 Nov 5 09:16 .. -rw-r--r-- 1 root root 261 Mar 24 08:42 bed.g -rw-r--r-- 1 root root 3857 Mar 26 11:04 config.g -rw-r--r-- 1 root root 3857 Mar 26 10:59 config.g.bak -rw-r--r-- 1 root root 3490 Mar 24 08:42 config.json -rw-r--r-- 1 root root 221 Mar 24 07:55 deployprobe.g -rw-r--r-- 1 root root 10324 Mar 16 07:11 Duet3Bootloader-EXP3HC.bin -rw-r--r-- 1 root root 9916 Mar 16 07:11 Duet3Bootloader-TOOL1LC.bin -rwxr-xr-x 1 root root 157308 Mar 16 07:11 Duet3Firmware_EXP3HC.bin -rwxr-xr-x 1 root root 560772 Mar 16 07:11 Duet3Firmware_MB6HC.bin -rwxr-xr-x 1 root root 408648 Mar 16 07:11 Duet3Firmware_MBP05.bin -rw-r--r-- 1 root root 160204 Mar 16 07:11 Duet3Firmware_TOOL1LC.bin -rwxr-xr-x 1 root root 33804 Mar 16 07:11 Duet3iap_spi_MB6HC.bin -rwxr-xr-x 1 root root 33804 Mar 16 07:11 Duet3iap_spi_MBP05.bin -rwxr-xr-x 1 root root 19908 Mar 16 07:11 Duet3_SBCiap_MB6HC.bin -rwxr--r-- 1 root root 19908 Mar 16 07:11 Duet3_SBCiap_MBP05.bin -rw-r--r-- 1 root root 1236 Mar 26 09:48 dwc2settings.json -rw-r--r-- 1 root root 1023 Mar 24 08:42 homeall.g -rw-r--r-- 1 root root 521 Mar 24 08:42 homex.g -rw-r--r-- 1 root root 521 Mar 24 08:42 homey.g -rw-r--r-- 1 root root 422 Mar 24 18:33 homez.g -rw-r--r-- 1 root root 397 Mar 24 08:42 pause.g -rw-r--r-- 1 root root 400 Mar 24 08:42 resume.g -rw-r--r-- 1 root root 224 Mar 24 07:55 retractprobe.g -rw-r--r-- 1 root root 175 Mar 24 08:42 sleep.g -rw-r--r-- 1 root root 207 Mar 24 08:42 stop.g -rw-r--r-- 1 root root 162 Mar 24 08:42 tfree0.g -rw-r--r-- 1 root root 222 Mar 24 08:42 tpost0.g -rw-r--r-- 1 root root 166 Mar 24 08:42 tpre0.g pi@duet3:~ $ sudo journalctl -u duetsoftwarecontrol -- Logs begin at Thu 2020-03-26 17:17:01 AKDT, end at Thu 2020-03-26 18:31:34 AK -- No entries -- pi@duet3:~ $ sudo service duetsoftwarecontrol restart Failed to restart duetsoftwarecontrol.service: Unit duetsoftwarecontrol.service not found. pi@duet3:~ $
A power cycle returned it to normal.
This is way above my pay grade.
Tia -
Well... my apologies. I managed to typo the last two commands (the log and the restart). They should have referred to 'duetcontrolserver'
Also, lets do just these two commands. The journalctl I originally gave will produce many pages of output... too much... so let's just do these two:
sudo service duetcontrolserver status
sudo service duetcontrolserver restartDespite that, we did get some data. We know the Pi itself was up and running, and that the Pi could see its own SD card. So we can pretty much rule out any further issues with the SD card itself.
Next time this happens, do just those two commands above, and lets see what we get.
Sounds good, thank you sir.
