homea.g not found
Do you, by some chance have an 'a' axis defined ?
DO you maybe have mis-spelled something when tweaking ? -
It would seem you have defined an A axis in your config.g file (most likely location).
Whenever you define an axis you need to create the corresponding home file.
I do have an A (4th) axis (CNC) but dont use an endstop or home file with it. Just use G92 to set 'home". Maybe I never noticed the error message before. Anyway thanks for the guidance gentlemen
I guess you could create a homea.g file and use it to create a manual homing file for the A axis. Allow movement of unhomed axis, then use M291 prompt command to jog the A axis to the wanted position and then G92 to set it.
Create homea.g and leave it empty.
@3DPMicro said in homea.g not found:
Just create the homea.g file and put the G92 command in it.
Damn guys. 3 great suggestions. Just have to figure out which one.
An empty homea.g file doesn't solve the underlying problem if you do have an A axis; but putting
G92 A0
in homea.g will zero the A axis as part of the homing (or as @Phaedrux mentioned with the addition of allowing you to jog the axis).Furthermore if you do the same in homeall.g it won't ask for homea.g (unless you actually press the Home A button or execute
G28 A
)For convenience I'd probably use
G92
in homeall.g andM291
in homea.g(homea.g is only called when explicitly homing A axis or after home all if homeall.g doesn't have a
G0 H1
for A, orG92
(or overriden withM564
) or thereabouts) -
Point taken. I very rarely use the 4th axis and when I do I indicate in the stock or part. There is no homing switch on it. So basically just need to have the error message go away but being able to jog after home all without having to send G92 A0 would help relieve the already arduous workload
then put
G92 A0
in both homeall.g and homea.g (the latter to allow zeroing A by using the home A button) -
cool. Thanks
@3DPMicro Hi,
While some folks optimize homeall to save time (I guess), I don't do that.
I simply have homeall call all of the single axis home files.
While this might not be as quick it also means I only have the homing code for a given axis in one file.
