Duet 2 Ethernet - problem with DWC
Only USB in the first posts.
DHCP - yes and fixed IPs.
Presuming the Duet is still in the same state as in the first post it should respond.
Are you sure your computer can reach that network? what does the
route
command in your shell show you? -
Sorry for having these in Finnish...
USB LAN (ethernet) seems to be ok. Duet is there too (I didn't put it in there though, that just showed up) but cannot be connected to.
hmm, try changing your netmask to 255.255.255.0 instead of 255.255.255.255 (or from /32 to /24).
same for the duet if neccecary.
actually, if you're using DHCP and getting a /32 address something is a bit strange. What does the ethernet cable from the usb ethernet adapter on the mac(?) connect to?
@bearer said in Duet 2 Ethernet - problem with DWC:
Directly to Duet
@PL said in Duet 2 Ethernet - problem with DWC:
Directly to Duet
then I'm not sure where the DHCP server comes from, the Duet does not provide one. Is the computer providing a DHCP service?
In any case the netmask will most likely have to change to something less than /32
I dumped the DHCP and forced the mask to 255.255.255.0 and now the thing seems to be working!
The only change that has happened between now and the last time I used the Duet is a Mac OS update so I guess something got messed up then.
I'm quite bad with computers and networks so Thanks a million!
What other options do you have for
Ah, too late, but you got it.
"Manually" with mask 255.255.255.0 worked.
yeah, i just didn't see your previous response while writing that question. all good!
