Z motor blew
Are those metal washers on the mounting hardware?
Bingo!!!
That's why they include nylon washers to use when installing the board. Shorted that bugger right out with those.
Ouch;
if you don't need all 5 drivers you can remap Z to use driver 4 which is normally E1 provided nothing else were affected.But I'd start by replacing the washers with something less conductive; and check the fuse if the remaining drivers don't work.
(Just took a peek at the board layout, unless the top side washer has a burr that cut through the solder mask I don't think its the culprit, but it does likely span over both GND and Z_MOT_1B traces. But still, start by removing the metal washers)
@bot - the nylon washer is under the metal one- the metal washer isn’t actually touching the board, but I do see your point.
@Thinepa This is why I asked a question instead of just pointing fingers. If there is a nylon washer underneath I can't see how it would be an issue, so long as there is no contact between metal and other areas.
@bearer - I was aiming to use E1, but would I still be able to use both z motors? I’m still learning (clearly), and am not sure if remapping the driver would allow me to use both z motor connections (the ones adjacent to the z motor driver) and the E1 driver, or if I could only use a single motor at E1.
@bot - I do appreciate that. I’ll remove the metal washers still - just in case.
@Thinepa said in Z motor blew:
the only magic there is for the z driver is that here is two headers that gives you convenient access to run two motors in series - you could replicate the same arrangement with wiring the motors in series before connecting to the single E1 header.
@bearer - that makes sense. Thanks!
but maybe find out what caused the short first so you don't end up with E1 sending smoke signals
@bearer - true. I’m thinking I mis-wired my z motors. Breaking out the multimeter to confirm.
Well - after some multimeter deciphering, I've come to understand that my z motor coils run A1 A2 B1 B2, whereas my other stepper motors run A1 B1 A2 B2. After removing all metal washers, rewiring and setting up my Z motors in series on my E1 driver, all of my axes seem to be working.
My last problem is that I keep getting an error on my Driver 2 that it's over temp. I'm certain that that chip has blown, but is there a way to "turn off" that driver so I don't continue getting that error? I can turn off the motor with M58, but that doesn't seem to affect the driver error.
Any thoughts?
Yes you can disable the driver using M569. Specifically the P and R parameters.
@Phaedrux said in Z motor blew:
Specifically, the R-1 parameter.
@Phaedrux - thank you very much. Worked perfectly. No more warnings.
@dc42 - the wiki is super helpful. So much to learn. Thank you!
