M558 Recovery Time
Is it just a RepRapFirmware 1 thing that this can't be less than 1 second? Not tested to see if it is limited to integer values or just over 1 yet...
You can use floating point values. We recommend 0.2 or 0.4 for the Smart effector.
More generally, in RRF almost every parameter that represents a continuous value is implemented using floating point arithmetic.
@dc42 don't think that's working for R/M558 in RRF1 or the time delay before a heater fault causes the build to cancel.
I'll confirm after I've made today's quota of faceshield frames.
You can send M558 without parameters to confirm what the recovery time is set to, even while you are printing.
