Solved Duet3 moving even when file is cancelled
I am experiencing some trouble with my duet 3 and pause/cancel functionality.
When I pause a file, it does the same thing as my duet 2 wifi, but when I cancel a file, the head of my cnc moves to a location several lines ahead in the gcode which was cancelled. This has crashed my machine several times and is quite annoying.Both pause.g and cancel.g are files empty of any gcode, containing only a comment which states their names.
Anybody else experiencing this issue or have a lead on how to fix?
Thanks,
T -
What firmware version are you using?
Please post your config.g, homing files, pause and cancel files. -
If you are using a Duet 3 with SBC attached, I suggest you try out the latest DSF version from the
unstable
package feed. See https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation for further details.There was a bug in RRF 3.0 which could cause the behaviour you're seeing, but it should be fixed in the latest version from the unstable package feed.
thanks @chrishamm
This fixed the issue.
