Solved z probe wont respond to G31
Maybe you're using config-override.g and there is still one defined in there? Does it work when you execute it from the DWC console?
thats where im changing it from the dwc,, funny thing ive allways had this prob.
there is no config.goveride file at all in my system.
baby stepping quit working when i changed to the v2 interface it only works if the printer isnt running a file weird ??
i have never been able to get an offset entered -
Make sure you don't have a G31 later in config.g. I use a macro to set it, since I use a few different filaments that use different temperatures. Like PLA and PETG.
No other entires just in config.g
Is G 31 the place i need to set my off
set?? Im not sure at all -
Do you have a G31 in your homing files or beg.g?
No more entries in any other files that i know of.
- Is it the height after homing Z that isn't changing? If so then that may indicate an error in your homeall.g and/or homez.g files.
- What Duet and firmware version are you using?
i believe the corect anser to be ver1.12
also remeber ihad to reload my www. file
so ver1.12. with the v2 dwc interface. would that be correct?heres the config g < home all< and the home z files for you to see
( ill remove G29 S1 )
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes forward
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwardsM569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
; M92 X79.7 Y320 Z400.4 E96 ; Set steps per mm
M92 X79.2 Y320 Z400.5 E96 ; Set steps per mmM566 X1600 Y500 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y1600 Z300 E1500 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z300 E5000 ; Set accelerations (mm/s^2) is 500
M906 x950 Y1200 Z850 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
; M208 X495 Y495 Z460 S0 ; Set axis maximaM208 X0 Y0 Z0 S1 ; Set axis minima
M208 X500 Y500 Z500 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set endstops controlled by sw. x controlled by capasitive sensor; Z-Probe
; M558 P5 H5 F100 T2000 ; Set Z probe type to capasitive and the dive height + speeds
M558 P5 H5 F100 T4000 ; Set Z probe type to capasitive and the dive height + speeds
G31 P500 X-42 Y-5 Z7.75 ; Set Z probe trigger value, offset and trigger height - is Nozzle higerM557 X15:215 Y35:215 S20 ; Define mesh grid
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S120 ; Set temperature limit for heater 0 to 80C
M305 P1 T100000 B4400 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 240C; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned offM106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned onhome all; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
; Enable Bed Leveling
G29 S1 ; Enable Mesh Bed LevelingHome All
G91 ; relitave mode
G1 S2 Z4 F3000 ; raize head 4mm
G1 S1 X-500 Y-600 f3000 ; move y and x to endstops in -neg direction until end sw trip
G1 S2 X4 Y4 f600 ; move slowly 6mm in + direction
G1 S1 X-10 Y-10 ; move up to 10mm in the Y- andX- directions untill the homming switches are trigered
G90 ; back to absolute mode
G1 X125 Y125 F3000 ; put head at fist probe piont
G30 ; lower head , stop when z probe is trigeredhome z
; homez.g
; called to home the Z axis
G91 ; relative positioning
G1 Z2.5 F6000 S2 ; lift Z relative to current position
G90 ; absolute positioning
G1 X51 Y20 F6000 ; go to first probe point
;G91 ; relative positioning
;G1 S2 Z2.5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
also just found this file called bed g.
M561 ; clear any bed transformG29 ; probe the bed and enable compensation
not sure, but is this for slicer start code??
will this also add another error for z offset or ??? is this one o k in its separate system fie
lets start over new thread
re ask the questionthis is where im at
duet reports z at 12.75 after homeing
trigger height is at 7.75
zerro is at is at 6.30during a print the duet throws back the Z tool position as 1.42 with the nozzle burried in the glass
in my mind all Entries are a positive #Z-Probe
G31 P500 X-42 Y-5 Z7.75 ; Set Z probe trigger value, offset and trigger height - is Nozzle hoger -
is this my error ...Z7.75 should it read Z-7.75 is it a flipin - that been hanging Me???
I dont know if it is related to your problem or not, but you should remove G29 S1 from config.g. You can not enable mesh compensation before homing. G29 should come after homing, not before.
i believe its commented out wouldn't that do the same
@ziggymanpopo said in z probe wont respond to G31:
G29 S1 ; Enable Mesh Bed LevelingDoes not seems to be commented out.
;G29 S1 -
think i did it right after im just stumped?? are my settings right ??
other than that ??
offset suppose to be a neg. # instead of pos #...maybe????
