BLtouch on Duet 2 Wifi RRF3
@Phaedrux ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.1 on Tue Jun 09 2020 17:05:22 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"CR10sPro" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M208 X330 Y320 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-40 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X40:300 Y15:300 S20 ; define mesh grid; Heaters
M307 H0 A200.4 C697.1 D0.3 V24.1 B0
M307 H1 A835.3 C298.2 D5.5 V24 B0; Fans
M563 P0 S"Hemeres" D0 H1 F0 ; define tool 0
T0 ; select first tool
M501
M575 P1 S1 B57600 -
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
;M280 P0 S10 ; deploy BLTouchM280 P0 S10 ;deploy BLTouch
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-335 Y-325 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-335 Y-325 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-405 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X40 Y15 F6000 ; go to first probe point
G1 H1 Z-405 F1800 ; move Z down until the endstop is triggered
G30 ; home z by probing the bed
G90 ; absolute positioning -
@mrenz999 Your config.g, change:
to
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
Your homeall.g is using a Z move to home the bed against an endstop:
...But your homez.g is using G30, as it should. If you use homez.g (or home just the Z axis) does Z home correctly? If so, replace:
in homeall.g with:
In both homeall.g and homez.g delete this line:
because the 'Z position' is set by the Z trigger height in your G31 command in config.g
Calibrate the Z trigger height in G31 by following this guide: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
@droftarts The probe will deploy with the m401 command. But on homing it has not deployed yet.
@mrenz999 said in BLtouch on Duet 2 Wifi RRF3:
How are you homing? Clicking 'HOME ALL'? It won't work for the reasons I've said. It might deploy if you 'HOME Z' only, but with the config.g incorrect, it will either be triggered already, or not trigger as it slams into the bed.
Rather than testing by pressing home, check the function as described here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Commissioning_Testing_RepRapFirmware_Num_3
Then do the changes I suggested in my previous post.
@droftarts Ok I did an individual home x then y then z. It deployed the pin and bounced back up. It was off the bed so I had to let it hit my hand. Then it shifted on the x to the middle of the bed and didn't deploy it just lowered until I turned it off. I did make the changes you suggested.
Do I need to do something to tell it to drop the pin each time it probes a spot on the bed ? -
No. It should deploy as needed with G30.
Please post your config.g and homing files again with your changes.
@Phaedrux
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
M501
M575 P1 S1 B57600; homeall.g
G1 H2 X150 Y150 F9000 ; go to first bed probe point and home Z
;G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G1 X40 Y15 F6000 ; go to first probe point
;G30 ; home z by probing the bed
; homeall.g
G90 ; absolute positioningYour homeall is incorrect. It should be:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-335 Y-325 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-335 Y-325 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 X150 Y150 F9000 ; go to first bed probe point and home Z G30 ; probe the bed ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning G1 X0 Y0 ; return to parked position
Same for the homez, it should be:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 X150 Y150 F9000 ; go to first bed probe point and home Z G30 ; home z by probing the bed ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning
@Phaedrux said in BLtouch on Duet 2 Wifi RRF3:
; homez.g
Thank you so much. That worked. Fixed the microstepping lol. Now to get the z height for first layer porn lol
@droftarts said in BLtouch on Duet 2 Wifi RRF3:
@mrenz999 that's where this comes in. After that you may want to do a mesh compensation heightmap to see how your bed surface looks.
