Initial Setup With new Duet 3
@dc42 Yes I used the web firmware configurator. I put in end stops. Pretty
new to Duet. -
Can you show a screen shot of what you had selected?
@Phaedrux
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 08:19:17 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode; Drives
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P2 C"io3.in+io3.out" H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X20 Y0 Z4 ; set Z probe trigger value, offset and trigger height
M557 X30:260 Y20:260 S20 ; define mesh grid; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M501Lol went back in and sure enough I did not select them. So now they are in there but they are backwards, triggers when not triggered. So I guess I will have to switch the wires.
@mrenz999 said in Initial Setup With new Duet 3:
No. It sounds like you've specified active high and they are active low so the configurator has put a "!" before the pin name to invert the input. Just take out those exclamation marks in the M574 commands and you should be good.
@deckingman
That's easy, thank you. The next thing I have to figure out is I have a simpley IR device for my z probe. 3 wire. On the
Board io3 I used the first 3 pins starting at 5v which it is 5 v. It has it's own light and signals light on when it detects
the plate and off when it doesn't. The software says not triggered and never changes. -
@deckingman
the plate and off when it doesn't. The software says not triggered and never changes.It sounds that you have the output of the IR sensor connected to IO3_OUT. Connect it to IO3_IN instead.
Will do.. Thank you. -
Not sure if I should stay in this same thread or make a new one. I have a corexy and I believe either my x or y stepper motor is backwards. How do I tell ? I tried to home and all kinds of crazy grinding happened as the head jerked around. It's setup with x on the back left and y on the front right. Zonestar z9m3 is the model. Is there a way for me to test which way they are moving and which way they should be moving ?
Take a gander at this https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
Scroll down to the section entitled testing motor movement and run through the steps listed there.
@deckingman I gave that a shot. Had to make changes and both X and Y with the G1 S2 X10 F3000 command moved the head forward x and y diagonally. I tried to home the X and it moves negatively towards the Y Home and I home x and it sits there and makes a grinding sound. When I home z it moves up to the end stop which changes to 1000 but it doesn't stop it presses the Hotend into the bed. It activates around 5 mm from the bed.
Where are the endstops physically located on the printer? This will determine how you setup the M574 command. That will also dictate the direction of movement for the homing files. Those things are dictated by the physical location of the endstops. The motor directions need to be resolved separately based on the corexy motor tests.
So tell us where the endstops are physically located and post your homing files as well.
@Phaedrux So looking down on the printer from above. The X motor is in the back left corner. The endstop for it is on the right side of the of the Hotend. The Y motor is in the back on the right side of the printer and the endstop for it is at the motor in the far back righthand corner of the printer.
So the printer is homed at the far right back corner. -
@Phaedrux
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:21 GMT-0700 (Pacific Daylight Time)
G91 ; relative positioning
G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-335 ; home X axis
G1 H1 Y-335 ; home Y axis
G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-335 ; then move slowly to Y axis endstop
G1 H1 Z-405 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:22 GMT-0700 (Pacific Daylight Time)
G1 H1 Y-335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-335 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 H1 Z-405 F1800 ; move Z down until the endstop is triggered
;G90 ; absolute positioning -
Ok I have the motors working correctly. X and Y are homing correctly. I have z homing and the IR switch turning on (going to 1000) when activated but it doesn't stop the bed from rising when it activates.
Ok. Now I have all axis's homing correctly. After the Z homes it takes off
to the furthest point it can from the bed ? -
@mrenz999
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time); General preferences
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes backwards
M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M558 P1 C"!io3.in+io3.out" H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
G31 P500 X0 Y40 Z4 ; set Z probe trigger value, offset and trigger height
M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
M501New config.g
; homez.g
; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
G1 X150 Y150 F9000 ; go to first bed probe point and home Z
G30 ; home z by probing the bed
;G90 ; absolute positioningNew homez
It sounds like you've got that resolved based on your other thread.
So the printer is homed at the far right back corner.This would be a flipped orientation compared to having the motors in the front, but that doesn't really matter. It's all relative to the way you are looking at it and where you want to place the coordinates. The important thing is that you have a right handed coordinate system so that it matches the way the slicer prepares the files so that you don't get mirrored parts. So be sure to test for this. It's quite possible to have things appear to be working, homing works correctly, etc, but then you go to print some text and it comes out totally backwards and upside down.
If that ends up being the case check out these threads and see if they help make sense of it.
https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4
https://forum.duet3d.com/topic/12676/mirrored-x-axis/9 -
@Phaedrux ok I have it all moving correctly for homing. All axis’s homing properly. PID tunes and printed a very sad looking xyz cube. Started printing a perfect square then it moved over and put another layer weirdly off the square.
