Strange homing behavior
I do not think that I can have two files with the same name in the same directory on a FAT filesystem.
And it makes no difference whether the code is hosted directly in the homeall.g or if I execute the homez.g from the homeall.g. I still wounder about the single blink of the IR-Probe in the travel.Btw: The IR Probe blinks 4 times when it starts up. I'm not sure that this is correct. I have something on top of my head that there was something like "analog mode (less than 4 blinks) with or without the pullup (^)". :?
@Chriss I didn't mean two files in the same directory, but one in sys, one in root. Please check whether you have files in your root directory...
@JoergS5 Guten Abend.
Well, I think that I got your point, but this is not the case:
150 Here comes the directory listing. drw-rw-rw- 1 ftp ftp 0 May 13 2020 gcodes drw-rw-rw- 1 ftp ftp 0 May 13 2020 macros drw-rw-rw- 1 ftp ftp 0 May 13 2020 sys drw-rw-rw- 1 ftp ftp 0 May 13 2020 System Volume Information drw-rw-rw- 1 ftp ftp 0 May 13 2020 www -rw-rw-rw- 1 ftp ftp 5734 Aug 08 2018 DuetDriverFiles.zip drw-rw-rw- 1 ftp ftp 0 May 12 2020 .Trash-1000 drw-rw-rw- 1 ftp ftp 0 May 15 2020 filaments 226 Transfer complete. ftp>
I added some eyecatcher code (some extra movement) to the homez.g, I see that eyecatcher when I execute homez.g and homeall.g. So there is no other file/config involved here.
@Chriss Ebenfalls Guten Abend!
Sorry for my crazy ideas, I try to find the reason also...
I don't know a difference between running in homeall and calling a macro containing the commands. In fact, some users use homeall to put in solely three calls to the homex/y/z macros.Back to the sensor: is it the Duet sensor? Do you know David's blog https://miscsolutions.wordpress.com/mini-height-sensor-board/
This may give some more hints. -
It is official now, it is snowing in hell!
I played a bit with that extra move.. just for fun to see where the extra blink comes up and where not bla bla....
So I added "G1 Y300 X300 F6000" on top of the homez.g. Again, just for fun. So the printer homes XY (0) via homeall.g and travels than to the other site of the bed. Instead of going straight to the center.
And you know what? It worked now 3 times in a row. I will play a bit more.... -
But I still think that there is a difference between homeall.g and homez.g.
I have changed the homez.g a bit. I have now a "run 1" with a "G1 H1" and a little lift of that afterwards. Than the "run 2" with the "G30":
G90 M300 S800 P100 G1 Y155 X155 F6000 ; go to first probe point M300 S300 P300 M400 M600 S800 P500 G91 ; relative positioning ; Run 1 G1 H1 Z-500 F200 ; move Z down until the endstop is triggered G1 H2 Z5 F6000 ; lift Z relative to current position M400 ; Run 2 M558 F60 ; Chriss - set the down speed M600 S800 P2000 ; beep G30 M558 F350 ; Change the speed back
Step one get executed whether I call homez.g or homeall.g, but "step 2" produces a:
Error: Z probe already triggered at start of probing move
WHEN I execute it via homeall.g. It works fine when I execute homez.g.
@Chriss so homeall sets some precondition which is different from when you call only homez. So need "only" shorten homeall until you find the reason...
How have you wired the probe?
Please post your full config.g
Do not use G1 H1. It is for endstop and negates all of the probe settings. -
@JoergS5
Yes, that was my idea too, bit look at it, there is not much to remove without making it completely useless. I need a homed X and Y to move Z.@Phaedrux said in Strange homing behavior:
I connected it to "zprobe.in", VCC and GND from the same connector. The ir-probe is much more user-friendly than the bl-touch.
I do not expect a problem with the ir-touch itself, it worked more than 99,998% if I use "homez.g"
You will find it at the end.
Do not use G1 H1. It is for endstop and negates all of the probe settings.I changed the config a bit this morning. I have now:
Homez.g
G90 G1 Y155 X155 F6000 ; go to first probe point M400 G91 ; relative positioning ; Run 1 M558 F250 ; Chriss - set the down speed G30 ; Run 2 M558 F60 ; Chriss - set the down speed M600 S800 P2000 ; beep G30 M558 F350 ; Change the speed back
And homeall.g
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-315 Y-315 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-315 Y-315 F360 ; move slowly to X and Y axis endstops once more (second pass) M98 P"0:/sys/homez.g"
config.g
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 08:05:32 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Homer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backward M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2:9 E3 ; Chriss - set drive mapping two Z motors connected to driver outputs E6(9) and Z(2) M671 X-28:330 Y155:155 S5.5 ; Chriss - leadscrews at left (connected to E6(9)) and right (connected to E2) of X axis (S=MaxCorrection) M350 E16 I0 ; Chriss - without interpolation M350 X16 Y16 Z16 I1 ; Chriss - configure microstepping with interpolation M92 X80.00 Y80.16 Z400.00 E431.06 ; Chriss - set steps per mm 2560 From Bondtech: E409.51 Original: E137.81 Calulator: ; https://3d-druck-archiv.de/blog/grundlagen-3d-druck/steps-fuer-x-y-z-achse-einstellen-ueberpruefen-247 ; https://selbstgedruckt.de/berechnungstools/ M566 X900.00 Y900.00 Z12.00 E120.00 ; Chriss - set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z800.00 E1200.00 ; Chriss - set maximum speeds (mm/min) Z180 M201 X500.00 Y500.00 Z20.00 E250.00 ; Chriss - set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0:310 Y0:300 ; Chriss - X carriage moves from 0 to 310, Y bed goes from 0 to 310 ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe IR Probe M558 P1 C"^zprobe.in" H5 F120 T6000 G31 P500 X-26.0 Y-9.0 Z1.85 ; Z-probe location and offset ; M564 S0 to disable axis limits. ;https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe ;M557 X10:270 Y40:270 P10:10 ; Chriss - define mesh grid M557 X10:270 Y40:270 P5:5 ;M557 X10:270 Y40:270 P2:2 ; https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid ;; Heaters ;BED M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 A245.4 C400.5 D1.3 S1.00 V24.1 B0 ; Chriss - Disable bang-bang, tuned with "M303 H0 S80" ; https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161 M140 H0 ; map heated bed to heater 0 ; Hotend M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 A461.2 C156.1 D3.1 S1.00 V24.0 B0 ; Chriss - tuned with "M303 H1 S250" ;; Fans ; Fan for the printed part: M950 F0 C"duex.fan4" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Fan for the Hotend; M950 F1 C"duex.fan3" Q500 ; F="create fan 1" C="on pin duex.fan3" Q="and set its frequency" M106 P1 S1 H1 T45 C"Hotend" ; P="set fan 1" S="value" H="Thermostatic control Heater No." T=" is turned on at 45°C" ;; Tools ; Tool 0 M563 P0 S"Extruder" D0 H1 F1 ; define tool 0 (Fan F1 is bonded automatically) G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ;; Filament Sensors - https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors ; Sensor 0 M591 D0 P1 C"e0_stop" S1 ; filament monitor connected to E0_stop ;; Misc ; Configure Port for the PaneDuo M575 P1 B57600 S1 ;; EOF
Do you have a Duex?
M584 X0 Y1 Z2:9 E3
Drive 9?
If so, you may want to define it here:; Drives M569 P0 S0 ; physical drive 0 goes backward M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards
M350 E16 I0
No interpolation for the poor extruder?The M140 must come before the M143 for your bed heater.
;BED M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 A245.4 C400.5 D1.3 S1.00 V24.1 B0 M140 H0 ; map heated bed to heater 0
M600 isn't a beep. It's a filament change pause.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M600_Filament_change_pause; Run 2 M558 F60 ; Chriss - set the down speed M600 S800 P2000 ; beep G30 M558 F350 ; Change the speed back
You'd want M300
https://duet3d.dozuki.com/Wiki/Gcode#Section_M300_Play_beep_soundI'm actually wondering if some of your comments are being parsed strangely. The forum code block gets pretty confused by them as you can see, but when I copied and pasted it into a text editor with gcode highlighting it detected the comments ; correctly. Not sure how the Duet gcode parser could be handling it. Might be worth cleaning up your comments to be rather minimal particularly in the area where the URLs are.
Can you send M558 P1 and G31 and see if it echoes back the same values as in config.g?
Do you have a Duex?
M584 X0 Y1 Z2:9 E3
Drive 9?Indeed, I have one and it is connected.
[...]Added
M350 E16 I0
I had some strange behaviors in the past with the original extruder. That may be different now with the bondtech. Well, I added it. Lets see later how that works now.The M140 must come before the M143 for your bed heater.
[...]Done!
[...]You are right, my bad. I wanted to change the frequency, which ended in the "double comand" and not "double frequency". Typo, I removed all of the beeps in the meantime anyway. They where for debug only anyway.
[...]Indeed, that is a very good idea. I removed all the URLs and removed other things like "°". Just in case, that would not be the first time that I have bombed a parser with unexpected characters.
Update:
I tested/played a bit with the setup to understand the behavior better.
Let me describe it like that: The "homeall.g" seems to work from time to time when "z" is not far away from the bed surface. But sometimes it drives into the bed.
It seems that it gets triggered in the air only when "z" is more than 10cm away from the bed when I power on the printer. It works or drives into the bed when the head is below 5cm away from the bed.
Did it make myself clear?
Does that makes any sense to you?Cheers, Chriss
I thought we would at elast get something back from M558 P1.
Please try sending the full M558 command from your config.g in the console.
I can't remember if I asked before, but can you send M98 P"config.g" and see what you get for errors and messages?
I did not fully understand what you mean. I added "M558 P1" at the end of config.g, without any result. I do not see any output of that, nowhere.
I tried telnet:
[chriss@leela ~]$ telnet 192.168.1.170 Trying 192.168.1.170... Connected to 192.168.1.170. Escape character is '^]'. M558 P1 ok
I guess that you mean "M98 P"0:/sys/config.g""
[chriss@leela ~]$ telnet 192.168.1.170 Trying 192.168.1.170... Connected to 192.168.1.170. Escape character is '^]'. M98 P"0:/sys/config.g" HTTP is enabled on port 80 FTP is enabled on port 21 TELNET is enabled on port 23 Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 270C Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 486C ok
So no parsing error if you where aiming for that.
Cheers, Chriss
I mean send this in the console
And then try your homing.
Though I'm starting to wonder if it's something wrong with the IR probe itself.
Done, with the same result, the probe get triggered in the air.
I have to admit that you may be right. I have in total 3 of the ir-probes here. Two for my corexy build and the one in my CR10.
I replaced the one at my CR10 now with a other one. That seems not brand new any more, but it seems to work now. :?
But it is a bit to early for me to blame the bl-touch. I will play a bit more with the new one before I will confirm that the new one is working.And I will put the suspicious probe into the corexy for some tests.
Can you explain the homeall.g to me, please?
I'm fully confused now. I removed the "M98" so source the homez.g from the homeall.g. So it looks like that now:; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 08:05:32 GMT+0200 (Central European Summer Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-315 Y-315 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-315 Y-315 F360 ; move slowly to X and Y axis endstops once more (second pass) ;M98 P"0:/sys/homez.g"
And you know what? The printer homes Z after it homed X and Y. WTF? I added a "beep" into the homez.g to test whether it get executed and not. And the printer beeped when I executed "G28" right after it homed X and Y.
So I think that the homez.g is executed whether I execute it or not.
Is that the expected behavior? -
@Chriss said in Strange homing behavior:
Do you mean your "IR probe" is a BLTouch? This would not be an IR probe and is configurated differently.
@JoergS5 said in Strange homing behavior:
Ahhhh.. no.. it is a IR-Probe! Not a BL-Touch, I replaces the BL-Touch with the IR-Probe.. sorry for the confusion. Forget the BL-Touch please..... My bad.
@Chriss ok - this would be the easist solution
@Chriss if you run homeall and the Z is homed unexpectedly: do you have any special files lying around in the sys or macros folder, which could produce this behavior (tool changing, override,...)? To find the reason, you should delete every files and lines which are not needed. (backup all first)
