Can Duet report on stepper current?
@fcwilt said in Can Duet report on stepper current?:
What I was thinking of was a feature to generate a CSV set of current readings for a given move in such a way that I could generate a graph of current versus time or perhaps position.
Note that the current through a stepper coil goes through a full sine cycle for each full step so 200 ups and 200 downs for each rotation. to measure this over time during movement will required a large amount of data.
It's feasible though if you are handy with arduino and such. For example, logging the readings from a current sensor into an SD card, but this will require some work.
@zapta said in Can Duet report on stepper current?:
It's actually a complete sine cycle every 4 full steps.
I think you would be interested in the power as the current is constant (but still sinusoidal) the voltage / power is what would vary depending on the load.
that information you might be able to derive from the load angle measurement the tmc driver has available (but I think you need to modify the firmware to write this to a file at a reasonable rate)
@bearer said in Can Duet report on stepper current?:
Yes, you are correct.
What I hoped to do was to determine if the load remained relatively constant over the range of travel for a given axis OR if there was some binding causing the load to vary.
@arhi said in Can Duet report on stepper current?:
There are "stepper motor analyzer" circuit's out there. They measure current, either on the shunt on the analyzer device (your stepper pass trough the device) or they can attach to the current sense resistors on the driver circuit directly.
That sounds like what I am looking for.
@fcwilt this here is probably meant by arhi: https://forum.duet3d.com/topic/12049/building-a-diy-public-domain-low-cost-stepper-motor-analyzer
The used ACS70331 to read current to voltage value is very fast and affordable. -
I have seen that device few weeks ago but can't find it now ... anyhow there's DIY here on the duet forum: https://forum.duet3d.com/topic/12049/building-a-diy-public-domain-low-cost-stepper-motor-analyzer
i think dc42 has commented on something with regards to getting the load angle / stall detection threshold (same feature) iirc the value would be the max value over some interval so with a bit of scripting and repeat motion you might be able to detect variance along an axis.
i'll update if I find the post where that was discussed.
@dc42 said in Can Duet report on stepper current?:
Good to know. if so, what I call 'quadrant' in my stepper analyzer is actually a full step, not a 1/4th of a step. I will try to confirm with a measurement.
Thanks for all the feedback.
in case you missed the recent thread where it brought up the values are part of M122
https://forum.duet3d.com/topic/17740/driver-4-ok-sg-min-max-0-1023-what-does-this-mean
