Rectangular mesh grid
Hello all. Is there a way to define the mesh grids so that it takes a point every 50mm in the X but every 60mm in the Y?
Something like M557 X0:100 Y0:120 S50:60?
Yes I think you've got it
https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
I guess not having seen an example, It wasn't clear that it was possible. I suppose you can't have an example for everything. Thanks @Phaedrux
I guess the example is in the description of the S parameter
Saaa Probe point spacing (RepRapFirmware 1.19beta10 and later also support Saaa:bbb)
I'll add an explicit example.
I implemented this. Much better. Thanks @Phaedrux
