BLTOUCH SETUP - Struggling
Also - one piece of information that I may not have been clear about. If I manually retract the probe then request z to home and them manually touch the probe to cause it to retract (simulating the bed contacting the probe) - nothing happens. It's not "seeing" the z-stop trigger. Should it ? Independently of M401 /402 not working?
If M401/M402 don't work, how are you manually deploying the probe?
Do any of the other M280 commands for the BLtouch work? Self-test?
Most of the time when a BLtouch isn't working, it's a wiring issue. Bad crimp, broken wire, poor contact, etc.
Manual == with finger :-). i.e. retracting the probe (red light goes off) ...
I'm just 24 hrs into duet / riprap so not familiar with the M280 commands - will look them up and try a few. I'll re-terminate the connectors at the duet end and report back.
@stuartofmt said in BLTOUCH SETUP - Struggling:
Yeah that's not going to work. The pin is controlled by a servo which deploys and retracts it. The firmware keeps track of the deployed or retracted state. Manually pulling it out is not the same as deploying it.
Does sending
M280 P3 S10
work to deploy it?See the manual for other commands.
@Phaedrux said in BLTOUCH SETUP - Struggling:
M280 P3 S10
I changed the terminations and tried all the M280 commands - no response. I even tried from serial usb just in case there were responses I was not seeing in the web interface.
Is there anything that I can do to verify that the Duet board itself is behaving as it should (if the bltouch were working correctly)? e.g. simulate a z-stop on home? I'm beginning to suspect one or the other i.e. bltouch or duet ....
Thanks for hanging in there with me.
On a whim - I added I1 to the deployprobe.g and retractprobe.g commands i.e.
M280 P3 SXX I1 this seems to have worked. I will be more definitive once I (hopefully) get my bed probed and calibrated.
The BLTOUCH now deploys the probe on homeing the z axis and stops the bed (rising in my case) when it touches the probe.
M401 and M402 now work as expected. HOWEVER, M280 P3 S10 and M280 P3 S90 DO NOT cause anything to happen BUT adding I1 to these (and other M280) commands causes the expected behavior.
One thought though - the config.g and other files were created by the reprap configurator (without I1) and clearly the bltouch has worked for others without the I1 argument. Any idea what the differences are ?
I will continue with my configuration ....... Thanks for the help!
Doh! of course. The inversion. Half my brain is in RRF3 now, where inversion is handled differently. Sorry I should have caught that off the start.
I'll have to check the output of the configurator. When connected to the Duet Wifi expansion headers the signal needs to be inverted.
Just checked the configurator and it outputs the correct format. I chose heater Channel E6 in the bltouch servo control pin drop down, which is heater pin 7. Which is confusing in and of itself.
I suspect you might have chosen one of the Duex pin options, which does not require the inversion (It's already inverted)
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 12 2020 20:16:48 GMT-0600 (Central Standard Time) M280 P7 S10 I1 ; deploy BLTouch
In RRF3 the pin names become a lot more logical and the setup is a bit more straightforward. If you go through the configurator choosing RRF3 you will see the differences. RRF2 is at the end of it's road of development. Since you're new to RRF in general, it might not be a bad idea to make the jump to RRF3 now before you get to used to the old way of doing things.
Perhaps I can help my adding a bit of my experience with the BLTOUCH probe. My current config for the probe was
.... M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y490 Z300.0 S0 ; set axis maxima X: 500mm, Y: 500mm, Z: 300mm ; Endstops M574 X1 S1 P"!xstop" M574 Y1 S1 P"!ystop" M574 Z2 S1 P"!zstop" M574 E2 S1 P"!e1stop" .... ; Z-Probe ; BLTouch - via exp.heater7 M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board. M558 P9 C"^zprobe.in" H5 R0.2 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed M950 S0 C"exp.heater7" G31 P25 X11.5 Y-10 Z2.15 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment M557 X100:400 Y80:380 P5:5 ; Define mesh grid ....
I use RRF 3.11 (I believe the newest one) and have wired the probe exactly as you did. My 3 axes are all with endstops and homing is also done to reach these endstops. After homing, I usually go to the print bed center and lower the Z-axes down to about 100 mm above the print bed surface. I used "G30 S-1" to check for Z0.0 and adjusted the Z-axes max value accordingly for max = 286.5 mm. After this, the nozzle (probe offset 2.15 mm) will touch the bed when I move the hotend to Z = 0.0.
Normal G30 is then working fine (hotend + probe sty 5mm above the bed) and a subsequent G29 for the height map also is done for all requested matrix points.
The BLTOUCH docs mention several macros for Pin down/up and other actions, be sure to use the same Port P0 (from the M950 S0 C"exp.heater7" command) for example in Pin Down "M280 P0 10". I always get confused about the inconsistent namings in different commands but it is as it is.
I have run G29 several times and the results stay stable as well no hickups with the probe. I will keep it as a 2nd choice as I now have the Precision-piezo Orion 2 working and could get rid of that offsetting nozzle-probe with that variant.
I upgraded to RRF3 and have the bltouch working and bed mesh calibrated. Pretty straightforward. Only problem now is the extruder motor not recognized. I'll start another topic.
Again thanks for the assistance.
