Hemera goes wild! heat and no moving...
use a multimeter and measure the phases. see if each phase has the same resistance
@Phaedrux
OK... I´ll connect the new motor tomorrow. -
@Veti
resistance is fine.Thanks
have you tried a different cable?
When using a motor with a plug on the body and a separate cable, you MUST confirm the phases with a multimeter or by other means, because the pinout of the connector is not standardised. Although if the cable was supplied by E3D as part of the Hemera kit, it ought to match.
I found the hemera wiring to be different from my stock motor. I had to swap pins 3&4 when using the hemera.
here is my wiring table i used with the duet:
PDF: Extruder 0
https://drive.google.com/file/d/1IE73tfQX7RgpArzxZJwyxEA-VIYsMFzE/view?usp=sharinghttps://www.randoprojects.com/2020/07/26/ender-5-w-hemera-and-duet-2/
yes... 6 different cables which are working perfect since 2 months. Also with shaking the cables it´s working with normal nema 17 but not with the hemera. Try to replace the hemera today!
thanks -
@mitch
ah ok!!!! I´ll try it directly!
thanks -
@mitch
switching 3+4 pin was not helpful..Also interesting is, that the sound doen´t stop anymore. I must turn off the machine. otherwise the sound of hemera doesn´t stop
Thanks
I´m workig with this plugs since months and it works with the E3D slimlime motor. So I think the plug is ok... -
@barbarossa-cologne have you tested the phases yet?! Blindly changing the pins isn’t going to work, and may damage the Duet and/or the motor. Disconnect the motor cable from the Duet and check!
@droftarts
Couldn´t test it because I don´t have a multimeter.
I don´t understand that I can´t read how to wire the motor exactly. Only @mitch had the information about switching the 3+4 pin...
E3D needs the same good support like Duet does it...And at this moment, I don´t know if the motor is already not working anymore.
@barbarossa-cologne said in Hemera goes wild! heat and no moving...:
how did you measure the resistance that you said you did?
@Veti
A friend came to my house with a multimeter. -
https://e3d-online.dozuki.com/Document/GdYIUZMlaEoWbQhU/Hemera-Datasheet-(Edition-2).pdf
page 6 has the motor wiring.
but if your say that each phase had the correct resistance then the motor is fine and not broken.
are the colours of the wire matching on the duet side?
https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/TF1FBCbopEsxvYAv.huge
If you don't have a multimeter you can use this method to match the phases:
With the motor wires not connected to anything, spin the spindle between your fingers. Short two of the wires together, then spin the spindle again. If it is much harder to spin than before, those two wires belong to the same phase. Otherwise, try again with a different pair of wires shorted together.
@Veti yes
@Veti yes
