Extruder calibration problem
@boxprinter said in Extruder calibration problem:
I now have the problem that the printer stops moving during a print and does not react any more. With M122
if you have set all drivers to 256 microstepping you are overloading the cpu
@droftarts Maybo not so important any more since the changes:
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1
But I know that I schould update the firmware. I just finished the cabeling today.
@Veti Would x128 for XY, x64 for Z and x16 for E be ok? Say for ~ 120 mm/s
start with x16 and interpolation.
once you have your printer up and running, then you can experiment with other values. -
you should update to 3.1.1
Beta firmwares are not supported anymore after the final release -
@Veti Unfortunately I do not seem to be able to update via the Web interface.
Under Settings, I upload the new binary file and I get asked if I want to update.
Then this message appears:M997 S0 Firmware binary "Duet3Firmware_MB6HC.bin" not found
But when I go to the System Editor Tab I can clearly see the file.
It did not work either.
you might have to go to 3.0 first
try uploading
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3iap_sd_MB6HC.bin
and then upload
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3Firmware_MB6HC.binand then try 3.1.1 again
Unfortunately also nothing. Should I try the USB methode?
yes probably easiest to do the bossa restore
See here for instructions on updating from Beta12
This came to late, I already upgraded via Bossa.
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-19b2
Everything seems to be ok now with the exception, that my PanelDue 5i does not communicate with the Duet 3 any more. I thus also updated it with Bossa from v1.23.2 to v1.24 but it stil does not work.
The paneldue baud rate will need to be defined in config.g M575 P1 B57600 S1
Thanks!
Is there any possibility to choose which four macros are displayed on the control page? -
Yes. Macros in the root of the Macros folder will show up in the short list of 4 on the PanelDue. You can use a prefix number to sort them how you wish.
Ex:
0_preheat 1_center nozzle 2_turn heaters off 3_etc etc
the prefix will then be hidden.
