Printing temperature drops down
@Pertti
Material settings show standby temperature 150C. -
@Phaedrux said in Printing temperature drops down:
M98 P"config.g"
@Pertti said in Printing temperature drops down:
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
For starters I suggest you update to firmware 2.05.1.
Upload this zip file as is (don't extract it) to the /sys folder via DWC.
OK, firmware now 2.05.1. Thank's for smooth installing.
I repeated printing, but sorry to say, nothing changed. -
Is it actually set to 200? Your chart looks like it may have had a temp excursion and then dropped. Do you see any errors in the gcode console?
Can you share your full config.g and a sample gcode file?
What firmware version and DWC version are you using?
Please post the results of M122 and M98 P"config.g"
Config.g and sample gcode please
Ok, tomorrow.
M98 P"config.g"
I can avoid the problem by writing lines M104 S250 to the Cura machine settings/extruder starting code.
That means that I have to configure a new printer for every material, but that is actually good, because then you have all things set up for every material. -
You've got some problems in your config.g
6.10.2020 klo 8.59.59 M98 P"config.g" Error: Bad command: 0:/sys/config.g HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 480C. Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 524C. Error: G10: Attempt to set/report offsets and temperatures for non-existent tool: 2
First, at the very first line you're missing a ; to comment out the file name and path.
0:/sys/config.g
The heater warnings are nothing serious. https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
The tool definitions are incorrect and may be part of the problem with cura. The second tool has a G10 targetting T2, but there is only T0 and T1.G10 P2 R140
That should beG10 P1 R140 S0
Plus you have a redundant tool command for T0 at the end.; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P1 R140 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P2 R140 ; set initial tool 1 active and standby temperatures to 0C M563 P0 D0 H1 ; tool 0 uses extruder 0, heater 1 (and fan 0)
0:/sys/config.g ; Leaprog 200804 ; TITAN AERO ; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; Tässä versiossa y=z akselissa ; generated by RepRapFirmware Configuration Tool v2.1.5 on Sat Jan 11 2020 15:38:33 GMT+0200 (Itä-Euroopan normaaliaika) ; General preferences ;M303 H2 S240 ;Auto tuning Heater2 G90 ; send absolute coordinates... M143 M83 ; ...but relative extruder moves M550 P"Leapfrog-Duet" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives dualextruder M569 P0 S0 ; physical drive 0 goes forwards X M569 P1 S1 ; physical drive 1 goes backwards Y M569 P2 S1 ; physical drive 2 goes backwards Z M569 P3 S1 ; physical drive 3 goes backwards E0 M569 P4 S0 ; physical drive 4 goes forwards E1 ;; Drives titan aero ;M569 P0 S0 ; physical drive 0 goes forwards X ;M569 P1 S1 ; physical drive 1 goes backwards Y ;M569 P2 S1 ; physical drive 2 goes forwards Z ;M569 P3 S0 ; physical drive 3 goes backwards E0 ;TITAN AERO ;M569 P4 S0 ; physical drive 4 goes backwards E1 ;M584 X0 Y1 Z2 E3:4 ; set drive mapping M584 X0 Z1 Y2 E3:4 ; set drive mapping vaihdettu z-y M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X400.00 Y66.67 Z654.02 E144.00:144.00 ;dualextruder set steps per mm M92 X66.67 Y66.67 Z654.02 E137.00:137.00 ;M92 X66.67 Y66.67 Z654.02 E837.00:93.00 ;titan aero; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) ;M906 X800 Y1600 Z1600 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M906 X800 Y800 Z1600 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 M208 X270 Y300 Z200 S0 ; set axis maxima ; Endstops M574 Z0 S1 ; set active low and disabled endstops M574 Z0 S0 M574 X1 Y1 S1 ; set active high endstops ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:200 Y15:195 S20 ; define mesh grid ; Heaters ;M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 ;M143 H0 S120 ; set temperature limit for heater 0 to 120C ;M305 P1 T100 B3950 R4700 ; set thermistor + ADC parameters for heater 1 ;M143 H1 S280 ; set temperature limit for heater 1 to 280C ;M305 P2 T100 B3950 R4700 ; set thermistor + ADC parameters for heater 2 ;M143 H2 S280 M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T110000 B3950 R4700 ; set thermistor + ADC parameters for heater 1 oli100000 ;M305 P1 B4725 C7.060000e-8 ; titan aero M143 H1 S290 ; set temperature limit for heater 1 to 280C M305 P2 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 2 M143 H2 S290 ; set temperature limit for heater 2 to 280C M307 H1 A455.9 C183.2 D17.7 S1.00 V24.1 B0 M307 H2 A499.7 C172.7 D10.4 S1.00 V24.1 B0 M570 H1 P4 T25 s1 M570 H2 P10 T25 M570 S120 ; Fans M106 P0 S0.5 I0 F500 H1 T45 M106 P1 T45 H1 ;M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off ;M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off ;M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 T45 B0.1 H1 ; enable thermostatic mode for fan 1 M106 P0 T45 B0.1 H1 ; enable thermostatic mode for fan 2 ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P1 R140 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P2 R140 ; set initial tool 1 active and standby temperatures to 0C M563 P0 D0 H1 ; tool 0 uses extruder 0, heater 1 (and fan 0) ; Custom settings are not defined
Your fan settings are unusual. You've defined fan0 and fan1 twice, but differently. The second definition overrides the first.
Plus, the way you have the fans setup with fan0 and fan1 being thermostatically controlled, but your tool definition has fan0 as the part cooling fan. So you need to decide what your intention is and wire it correctly. Which fan is on which tool? Which fan is thermostatically controlled for a heatsink, and which is a part cooling fan.
Your slicer start gcode sets temps using
G10 P0 R140 S205 G10 P1 R140 S205
is that where you see the temp drop down? That would match your graph. Is that after you had made the change you mention?;FLAVOR:RepRap ;TIME:952 ;Filament used: 0.245115m, 0m ;Layer height: 0.15 ;MINX:115.018 ;MINY:109.322 ;MINZ:0.3 ;MAXX:144.369 ;MAXY:160.669 ;MAXZ:50.1 ;Generated with Cura_SteamEngine 4.5.0 T0 M190 S60 M104 S260 M109 S260 M82 ;absolute extrusion mode G28 ;Home G1 Z15.0 F6000 ;Move the platform down 15mm ;Prime the extruder G10 P0 R140 S205 G10 P1 R140 S205 G92 E0 G1 F200 E3 G92 E0 M83 ;relative extrusion mode G1 F1500 E-5.5 ;LAYER_COUNT:333 ;LAYER:0 M106 S25.5 G0 F3600 X116.544 Y111.12 Z0.3
Thanks a lot, Phaedrux. You gave me a good lesson. I think I need a couple of days to handle this. Anyway, line "G10 P0 R140 S205 G10 P1 R140 S205" has been there before I changed machine settings in Cura. The temperature matches reality.
The fans are something I need to take a look at. My previous board did not function these things at all, so I connected fans to the power supply.
BR Pertti -
I think if you remove those G10 lines from your start gcode you will solve the temperature drop problem.
