RRF 3.1.1 Probe Issues
; Configuration file for Duet WiFi (firmware version 3.1.1)
M550 P"BLV AM8" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M671 X0:220 Y110:110 S2 ; leadscrews left & right (Middle of the bed in the Y axis)
M350 X16 Y16 Z16 E16 I0 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E400.00 ; set steps per mm
M566 X1000.00 Y1000.00 Z40.00 E1000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z1000.00 E6000.00 ; set maximum speeds (mm/min)
M201 X2500.00 Y2500.00 Z100.00 E2500.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z720 E1500 I45 ; set motor currents (mA) and motor idle factor in per cent
M208 X-4 Y-50 Z0 S1 ; set axis minima
M208 X220 Y210 Z250 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop"
M574 Y1 S1 P"!ystop" ; set active low and disabled endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y37.5 Z0.70 ; set Z probe trigger value (was at P500, I am testing P1000), offset and trigger height (Higher is closer to the bed!)
M557 X10:210 Y10:210 S10 ; define mesh grid; Heaters
; Bed
M308 S0 P"bed_temp" Y"thermistor" T100000 B4138 R4700 ; New Value for 3.1.1
M950 H0 C"bed_heat" T0 ; New Value for 3.1.1
M307 H0 A135.7 C683.7 D2.1 V11.8 B0 S1.00 ; Disable bang-bang mode and add PID Values for the bed heater and set PWM limit
M140 H0 ; Map Heated Bed to Heater 0 on the GUI
M143 H0 S120 ; Set the Bed Max Temp to 120 Degrees; Hotend
M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F50 ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
M950 H1 C"e0_heat" T1 ; New Value for 3.1.1
M307 H1 A636.2 C264.9 D5.8 V11.8 B0 S1.00 ; disable bang-bang mode and set PID Values for the Hotend heater and set PWM limit
M143 H1 S270 ; Set the Hotend Max Temp to 270 Degrees; Chamber
M308 S2 P"e1_temp" Y"thermistor" T100000 B4138 C0 R4700 ; New Value for 3.1.1
M950 H2 C"e1_heat" T2 ; New Value for 3.1.1
M307 H2 A42.6 C3913.4 D5.0 V12.2 B0 S1.00 ; Chamber PID Values - Testing These!
;M307 H2 A11 C99000 D2000 B1 ; chamber heater operates in bang-bang mode
M141 H2 ; Map Heated Bed to Heater 0 on the GUI
M143 H2 S80 ; Set the Chamber Max Temp to 80 Degrees; Fans
; Part Fan
M950 F0 C"fan0" Q500 ; New Value for 3.1.1
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off; Hotend Fan
M950 F1 C"fan1" Q500 ; New Value for 3.1.1
M106 P1 S1 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
T0 ; select first tool -
Dunno if this is considered the correct way to do it or not but what works for me is the following
in my homeall.g files; homeall.g ; called to home all axes ; G91 ; Relative positioning G1 H2 Z5 F6000 ; Lift the Z axis G1 H1 X-320 Y-320 F7000 ; Move the X & Y axis's quickly towards their end stops (First Pass) G1 H2 X5 Y5 F8000 ; Then go back a few mm G1 H1 X-320 Y-320 F1000 ; Then Slowly approach the X & Y end stops (Second Pass) G1 X155 Y168 F7000 ; Go to the centre of the bed M558 A1 F600 ; Set a single probe move at a faster feed rate to get the nozzle closer to the bed G30 ; home Z by probing the bed M558 A1 F100 ; Set the second probing at a slower feed rate G30 ; Probe a second time to get a more accurate position G91 ; Relative positioning G1 Z5 F1000 ; Lift the Z axis G90 ; Absolute positioning
@dc42 If you see anything else in my config that could be wrong, please let me know. The Probe is a Pinda 5v
@CaLviNx Thanks, I will give this a try. I would rather fix the M558 in config.g though as this also happens in my mesh levelling.
@MichaelMD1978 said in RRF 3.1.1 Probe Issues:
in the config.g you can also specify the amount of times it carries out a probe A command
@CaLviNx Thanks
@CaLviNx how would that look in the config.g?
@CaLviNx This is my current M558:
How do I edit that to probe twice?
To be honest in RRF-3 im not exactly sure how you go about getting any subsequent probe to be of a differing speed to the initial probe, I would surmise there is some young pup of a computer whizz out there who can whip up some conditional g-code to do what you are asking.
Me myself and i would start by trying multiple copies of M558 both with A1 in the command but differing feed rates, the worst that can happen is that it doesn't work and you need to work out another solution.
M558 P5 C"zprobe.in" H5 A1 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds M558 P5 C"zprobe.in" H5 A1 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
Thats what i would try first but as i said it might not be the right way to do it.
@CaLviNx Thanks for the help mate, I will give it a try.
You need to add the A and S parameters.
If you wish to force it to always probe twice use A2 S-1. It will average the 2 readings. If A was 5 it would average 5 readings, etc.
If you wish to have it try to obtain two consecutive readings that are close in value you would use something like A5 S0.1
With those values it would would probe up to 5 times until 2 readings were within 0.1.
If it failed to obtain 2 readings within 0.1 it would average the 5 readings.
@fcwilt Thank you! That's perfect!
@fcwilt said in RRF 3.1.1 Probe Issues:
Yes that works to do multiple same speed probes but doesn't answer his initial question
it would probe once fast and once slow in each spot, now it only probes each point once? Has anyone else noticed this and how can I fix it?
@CaLviNx Thanks for all your help too mate, I don't really need them to probe at different speeds, just having it probe twice will also work for me.
Even if this is not really required by you, the point it raises it would be interesting to find if there is a solution.
at the moment, I believe the solution you're using is the only one @CaLviNx
I use the same thing. I think it's on the "list" to be looked at to allow different homing speeds i.e. fast and slow. -
@CaLviNx said in RRF 3.1.1 Probe Issues:
Well as you have determined the F parameter controls the probing speed.
That would seem to qualify as a solution.
When homing using endstop sensors the typical code has always include changes in the F parameter for the G1 commands.
