Homming problems for openPNP
@qlfecv said in Homming problems for openPNP:
*** Ethernet networking: The following lines are used for factory testing - PLEASE REMOVE THEM
Also, all commands that aren't gcode/mcode must be commented out with a
;FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
This might be a good start as well to ensure you have all the relevant commands.
As I said recently in another PnP thread, extruders are not axes. I suggest you create a new axis (e.g. C) for the nozzle rotation, using M584.
@dc42 I think this is a different person.
@Phaedrux said in Homming problems for openPNP:
Nice that more folks are using Duet+RRF in OpenPnP systems! We should add a wiki page on configuring RRF for OpenPnP.
Thanks for reply.
I have created the C axis and everything solved.
Also modify the configuration in openPNP to work with the new C axis.
I only found this post that publishes the config.g of an openPNP machine and uses the extruder for the nozzle in it, so don't create the C axis before.
It would be of great help a wiki page to people who want to use Duet on an openPNP.
Thanks for reply.
I'm glad you got it working.
I don't have a PnP machine, so although I can create the wiki page I would need input from you and/or other PnP users. If I create the page, can you add some content?
@dc42 said in Homming problems for openPNP:
Thanks for reply.
Sure
Thanks! The wiki page is at https://duet3d.dozuki.com/Wiki/Using_RepRapFirmware_with_OpenPnP. Let me know your name on the wiki and we'll increase your reputation score sufficiently to edit it.
I don't understand the name, sorry but English is not my native language.
Jose
You will need to go to the wiki page, then click Login at the top right. This will allow you to create a Wiki account. When you have done that, let me know what user name you chose.
Done, same name.
I wrote a test now.
@qlfecv, you now have enough reputation to edit that wiki page.
