Worng homing on a CoreXY and totally wrong step/mm
@Veti said in Worng homing on a CoreXY and totally wrong step/mm:
@the_dragonlord said in Worng homing on a CoreXY and totally wrong step/mm:
but now both X and Y homing are in the wrong directions
the direction of homing is the the home[xyzall].g
I've corrected the thermistor but now it appearsa the following error after a while:
what did you correct it with?
create the filament folder on the sd card on your computer
The thermistor I choose is:
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtempshould the filament folder be created empty?
that change would not cause the problem with the rise in temperature.
yes
yes
so what's the problem for the temperature? In console I see the bed temperature rises but after few seconds the error appears
@Veti excellent, all solved!!!
going back to the lead scew. what kind of leadscrew is it?
t8x2?
t8x2?
they are the original trapezoidal X5S lead screws I think they are T8 and I think the pitch is 2
The it should be 1600. There is a steps calculator at the Prusa website
so 1600 with a 3:1 ratio would be 4800
exactly but with this esteps it move much more mm
@the_dragonlord
with 8000 it would move even more
@the_dragonlord
of course....when I'll complete all the inital set ups I'll print the calibration cube and then I'll see....for now I'm struggling with the BLTouch
trapezoidal X5S
according to marlin its a t8x8 4 start
so 400x3 = 1200
try that
And Double check the Ratio of 1:3
@Veti I don't understand anything.....Now the X and Y home are correct but if I send G1 X10 the carriage moves in the wrong way........................WHYYYY???
@the_dragonlord
post your home script
@the_dragonlord
; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 25 2020 09:41:43 GMT+0100 (Ora standard dell’Europa centrale)
G91 ; relative positioning
G1 H1 X-320 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H1 X-320 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-320 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-320 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X30 Y30 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homeall.g
; called to home all axes
G1 H1 X-320 Y-320 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-320 ; home X axis
G1 H1 Y-320 ; home Y axis
G1 H1 Y-320 ; then move slowly to Y axis endstop
G1 X30 Y30 F6000 ; go to first bed probe point and home Z
;G90 ; absolute positioning -
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystopyour configuration says the endstops are at the maximum.
you want X1 and Y1
M574
UUUUUUUUUUUUUUUUUHH STUPID ME!!! I thought active-high meant that the tension value when triggered was high
