EDIT ignore as DUET says the problem doesn't exist.
This post is deleted! -
@CaLviNx said in IR Sensors with the Duet-3!!!:
This issue manifests itself by providing very inconsistent probing results with random height variations when a print is attempted
can you post the result of a m48
https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output -
From my understanding is that your P8 in M558 will always show 0 or 1000. For analog in you need a P1.
With Duet 2 and earlier Duets: Connect the VCC, GND and OUT pins of the sensor to 3.3V, GND and IN respectively on the Z probe connector, and select mode 1 in the M558 command. With Duet 3 main board, expansion board or tool board: Connect the VCC, GND and OUT pins of the sensor to 3.3V, GND and IN respectively on an IO probe connector, and select mode 8 in the M558 command.
think the analog input was cut from the duet 3! Not all pins are ADC capable on MCUs
@CaLviNx yep. thats why it is not possible to get a reading between 0 - 1000 because its only low (0) or high (1000)
@T3P3Tony would it be possible to use the thermistor input with P1 on the 1LC?
@CaLviNx can you try using a thermistor pin with P1? it could work. On a SKR 1.3 running RRF3 it does. First hand expirience
@CaLviNx The fact that you've always had good success with the IR probe on gen 2 products rather looks like you have fallen foul of one of the firmware limitations of gen 3 in that it only supports type 8 or 9 probes. The latest information is that this is will not be fixed. https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
Any chance you can connect the probe to the main board ?
@deckingman said in IR Sensors with the Duet-3!!!:
I have tested with the probe connected directly to the main-board and I still encounter the issue, But.... a penny might just have dropped!!
Thinking about it, the one thing I havent done is to test the sensor in mode P1 when connected directly to the main-board as the restriction of using P8 is only in place when using the tool board.
But IF that does cure the issue it yet again makes a mockery of the point of the tool board.
I will test and report back
Thank you for the nudge to the brain.
The Escher3D/Duet3D IR sensor works fine in digital mode with Duet 3. The LED will flash twice on power up, to indicate that it is in digital mode.
@dc42 said in IR Sensors with the Duet-3!!!:
If that is so please explain why the issue is occurring only Duet-3 boards but not on Duet-2 boards.
Yet again it appears that Duet is not interested in fixing issues with the "evolution" hardware and instead categorically stating that an issue a user is reporting doesn't exist, classy, real classy.
The documentation is out of date, because it assumes that an IR sensor connected to a Duet will always run in analog mode. That isn't the case with Duet 3. We will correct the documentation.
Edit: now done.
@CaLviNx
Come now, you know that's not true.
