Problems with Using the manual bed levelling assistant
@the_dragonlord said in Problems with Using the manual bed levelling assistant:
G31 P500 X39 Y0 Z1.538 ; set Z probe trigger value, offset and trigger height
you specified that your probe is to the right of the nozzle, but the picture shows its on the left
@Veti said in Problems with Using the manual bed levelling assistant:
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHH I had to write -39?
@the_dragonlord
yes
please read
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2 -
@the_dragonlord
yes
please read
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2Yes yes, sorry, I didn't mind to type an "?" but an "!".....thanks
@the_dragonlord
yes
please read
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2now the probing go fine but in the end I see the error:
M98 P"0:/macros/Bel leveling assistant"
Error: Calibration failed, computed corrections: nan nan nan nan nan nanM98 maybe because I've made a Macro but if I send G32 directly the result is the same
G32
Error: Calibration failed, computed corrections: nan nan nan nan nan nan -
@the_dragonlord
execute each statement manually and see which one fails
@the_dragonlord
none of them:
1/11/2020, 17:48:12 G30 P5 X5 Y5 Z-99999
1/11/2020, 17:47:58 G30 P4 X165 Y5 Z-99999
1/11/2020, 17:47:47 G30 P3 X300 Y5 Z-99999
1/11/2020, 17:47:31 G30 P2 X300 Y320 Z-99999
1/11/2020, 17:47:17 G30 P1 X165 Y320 Z-99999
1/11/2020, 17:46:59 G30 P0 X5 Y320 Z-99999Can be the S6 after the last G30 in the bed.g?
what are you actually trying to do?
I've lunched the G30 manually one by one and none of them gave me the error but when I run G32 it appears the error
@the_dragonlord
no why are you running the G32?
@the_dragonlord
to have an idea on how to adjust the 6 screws.....wouldn't be this the purpose of G32?
@the_dragonlord
as wrote here: https://forum.duet3d.com/topic/12356/error-calibration-failed-computed-corrections-nan-nan-nan-nan/2
In the last G30 I've changed S6 with S-1 and I get:
G32 bed probe heights: -0.634 -0.719 -0.818 -0.339 -0.068 0.045, mean -0.422, deviation from mean 0.327
try redung the x300 value in your bed get to 290
ook, thanks
ook, thanks
I've adjusted the screw and now I got
G32
G32 bed probe heights: -0.369 -0.432 -0.442 -0.440 -0.284 -0.312, mean -0.380, deviation from mean 0.063It doesn't seem too bad, inst'it?
Now I'm starting to build the height mesh with G29 S0 let's see what happens
@the_dragonlord
only allows for max of 4 points
@the_dragonlord
uh, that was the problem...ok, thanks
@the_dragonlord
Here's my height map....looking at the graph it looks awful is it really so?
@the_dragonlord
that depends on the prints it produces. -
@the_dragonlord
uh, yes, of course....now I'm printing a bed leveling test in wich start GCode I've placed:G28 XY ;Home XY
M561 ; Clear any bed transform that might be in place
G1 X165 Y165 ; Move Probe to middle of bed
G30 ; Do a single probe
G29 S1 ; load height map
G1 Z20.0 F6000 ; Move Z to 20we'll see....
