Unsolved Motor issue, step forward and backward when change direction.
And you've tried with another motor? Another driver?
What commands are you sending to produce the movement?
Yes I've changed the motor by another one, new, and the same results appeared.
Does it happen on all drivers, or just one?
@Phaedrux Only in Y axis.
@Pasquk2
please reassign the y axis to another port and test againi.e
to
M584 X0 Y4 Z2 E3 ; set drive mapping -
Sorry for the delay.
I've changed the command but the Y axis doesn't move.
This is the error message from system: -
check your wiring.
did you plug in the cable into e1 on the board? -
Sorry, was not well connected. Is the problem when do things in the dark.
Trying now to print some circles and figures to prove all is ok.
I'll come back with results.Thanks.
I have problems now with the extruder. It does not extrude.
Left it for tomorrow. Too late for me. -
Today I've made a visual control printing test without filament and still produce the same hitch in the motor of Y axis.
to sum up.
you changed to driver on the duet to a different port -> no change
you changed the motor and its wiring -> no changedo you have pressure advance active?
did you try a differnet slicer?
@Veti said in Motor issue, step forward and backward when change direction.:
Sorry, but, dont know what "pressure advance active" is. Where can I find it?
I've tried, simplify3d, repetier, prusaslicer and cura, and all get the same results.
@Pasquk2 said in Motor issue, step forward and backward when change direction.:
https://duet3d.dozuki.com/Wiki/Pressure_advance
M572
If this must be in config.g file, I don't find it.
most of the time you put it the in the start g code of a file.
you can also just send M572 D0 in the console to query the current value
This is the result of m572 D0:
I'm going to erase all and reload the firmware again, begining from 0.
That means pressure advance is disabled. So that's fine.
Hi all again.
This weekend I've been so busy with my printer and tried many things. I have reset the board, erase sd card, reloaded all files, all firmware, and saddly all runs the same way. Still this bullshit movement in the motor.
I think there is some problem with the duet. Maybe some component broke.
I'll try more.Thanks all.
