rought outside surface
Is it the same with different filaments (PLA, PET, etc...)
i had similar problem with PLA but none with ABS last time i printed it , any more square print seem to be mostly fine it only when the shape start to be more complicated
printing in vase mode i get none of these issue with the same material
@Dad003 said in rought outside surface:
M350 X16:16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
M92 X160.00:160.00 Y160.00 Z6400.00 E186.5:186.5 ; set steps per mm
M566 X400.00:400.00 Y400.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X3500.00:3500.00 Y3500.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X140.00:140.00 Y140.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1450:1600 Y1600 Z1650 E1500:1500 I25 ; set motor currents (mA) and motor idle factor in per centyou can not have different settings for x. but i dont think thats causing your probelms.
@Dad003 you don't have your slicer set to put the seam at random locations do you? Could be issues with retraction on layer change. Vase mode wouldn't show it, and square sides objects might hide it better?
Other thoughts.
Have you done a temperature tower to check the best temperature to print at? Getting your thermistor setting right is good and all, but you will probably still need to try a range of temperatures to get it spot on.
How old or cheap is your filament? I had very similar issues with some old and cheap filament that went away completelywhen I got a new roll of something slightly better. I think it was mostly down to moisture from storing too long. I don't think ABS is quite as bad for it as PLA or PETG (which fits your findings) -
that because i got 2 different motor each using a different slot on the duet, at some point i need to get another one .
all my material is brand new , i get it from https://filaments.ca . it really dry around here , humidity level are always really low here .
i tried to enable coasting for some test and it was worst so maybe i need to reduce lower PA maybe . ill do a few more test once i get the few things in waiting for
You will get better surface quality in Cura is you set it to print inner walls > outer walls > infill and to align the seam. That will usually be enough to hide any imperfections from layer change retractions.
Many settings in Cura are hidden by default and there are a lot of settings to choose from. It will take some poking around and google searches and testing to get it mastered.
so i think i found my problem here ,it the extruder that seem to lack of strength sometime to pull the filaments , seem like i might have to either think about a solution or order a different model of extruder , it the downside of an non-geared extruder .
M308 S0 P"temp3" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin temp3
btw if this is your hotend you are printing with, then you are printing at the wrong temperature.
i assume you wanted to configure an e3d thermistor. that is B4725 C7.06e-8. the c value is very important
ah i see its your bed
that was the heat bed but i corrected that now ,
Thinking sometime to go to a bowden setup i think i could have a maximum of 400mm long maybe shorter depending were i put the extruder , then i could go with 2 bondtech single extruder and still be able to use the current hotend and nozzle , it would get rid of the 2 steeper motor on the head , i could bump the acceleration and jerk as well ,
any opinion about this , since it seem current extruder lack of pulling power ?
@Dad003 if I'm honest, I've just done the opposite conversion on my machine. Originally I had 2x BMGs with pretty powerful Nema17s, 700mm bowden into a Chimera. (Bed size is ~300mm square for ref) Granted with a shorter bowden length, most bowden related problems will be much reduced, but here's my thoughts.
I found that I was struggling to get extrusion under control and needed really high pressure advance. With that, my extruders were struggling to keep up and became my limiting factor for print speed. I probably could have tuned it more/better and there may have been some other issues impacting (old/moist filament I mentioned earlier...), but I spent a few months calibrating and sort of hit a wall.
In any case, I decided to go direct drive. I still use the BMGs but have switched to smaller pancake stepper motors. My carriage is now quite a bit bigger/heavier, but compared to the weight of the other moving components (the long x gantry in particular) its really not as bad as you think.
The one trouble I did have was that I couldn't quite get the BMGs close enough to line up the filament paths to the chimera inputs. In the end, I ended up with a ~5cm ptfe tube from extruder to hotend which gave enough room to account for the offset.
With the direct drive layout, I find I get much better results as I have better control on extrusion. I have had to slow it down a bit as the extruder has less power. Previously I could run at ~13mm^3/s volumetric flow, whilst now I find 10 is a safer limit, but I tend to use smaller and layers nozzles so rarely hit those limits anyway. I also use the accel control in the slicer to do perimeters slower/smoother, then can go harder on the infil where you won't see the ringing.Looking at your machine pics, I'd reckon you could get a geared extruder in your current setup, so I'd be tempted to give that a go first (especially if you're already getting the BMGs)? If its only occasionally slipping, having 3x the extrusion force should stop your current issues.
@engikeneer you might be right , there after thinking that more in deep i would probably ended up to have 1 inch or 2 of ptfe tubing , just because the BMGx2 has a 20mm spacing while my flexion bracket has 34mm ,
the next question would be 2 single bmg or the X2 model , 2 single will be easier to align might be harder to mount , price wise the x2 model come whit pancake stepper already and is cheaper than buying 2 single bmg
@Dad003 in my case, I'd bought mine separately (first one when I first buuilt the printer with a V6 hotent, then a second when I went dual)
I'd be tempted to go for the X2 as it will likely also give slightly smaller packaging, but the main thing would be how easily it all mounts into your carriage.
On the pancake motors, I use the E3D ones which are similar specs to the Bondtech ones, and I'm pretty happy with them. Bondtech is 1.8deg and slightly higher torque which may be better suited. Though you can always put your larger motors on if they fit/you want even more power!
