Board not connecting to Wifi: no know networks found
=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1-diabase running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DGM-917NK-F23T0-6JKF8-3SJ6P-TZ8NG<LF>Used output buffers: 1 of 24 (24 max)<LF>=== RTOS ===<LF>Static ram: 26128<LF>Dynamic ram: 95004 of which 0 recycled<LF>Exception stack ram used: 352<LF>Never used ram: 9588<LF>Tasks: NETWORK(ready,1100) HEAT(blocked,1232) DUEX(suspended,144) MAIN(running,4120) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:05:22 ago, cause: power up<LF>Last software reset time unknown, reason: Heat task stuck, spinning module Platform, available RAM 9280 bytes (slot 3)<LF>Software reset code 0x00a0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20004954 Task 0x4e49414d<LF>Stack: 0044f997 0044f778 61000000 3f800000 3fdb4e81 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f bda02214 3e3a3498 3e638fa9 3e924a09 3bc8553b c0a00000 3f800000 3f800000 20000010 ffffffff 20009354 00000000<LF>Error status: 4<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 28.7, current 32.5, max 32.8<LF>Supply voltage: min 0.6, current 0.7, max 0.7, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG min/max not available<LF>Driver 1: ok, SG min/max not available<LF>Driver 2: ok, SG min/max not available<LF>Driver 3: ok, SG min/max not available<LF>Driver 4: ok, SG min/max not available<LF>Driver 5: ok, SG min/max not available<LF>Driver 6: ok, SG min/max not available<LF>Driver 7: ok, SG min/max not available<LF>Driver 8: ok, SG min/max not available<LF>Driver 9: ok, SG min/max not available<LF>Date/time: 1970-01-01 00:00:00<LF>Cache data hit count 533347494<LF>Slowest loop: 100.12ms; fastest: 0.05ms<LF>I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0<LF>=== Move ===<LF>Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms<LF>Bed compensation in use: none, comp offset 0.000<LF>=== DDARing ===<LF>Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0<LF>=== Heat ===<LF>Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1<LF>=== GCodes ===<LF>Segments left: 0<LF>Stack records: 2 allocated, 0 in use<LF>Movement lock held by null<LF>http is idle in state(s) 0<LF>telnet is idle in state(s) 0<LF>file is idle in state(s) 0<LF>serial is ready with "M122" in state(s) 0<LF>aux is idle in state(s) 0<LF>daemon is idle in state(s) 0<LF>queue is idle in state(s) 0<LF>autopause is idle in state(s) 0<LF>Code queue is empty.<LF>=== Network ===<LF>Slowest loop: 1.25ms; fastest: 0.00ms<LF>Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)<LF>HTTP sessions: 0 of 8<LF>- WiFi -<LF>Network state is running<LF>WiFi module is idle<LF>Failed messages: pending 0, notready 0, noresp 0<LF>WiFi firmware version 1.23<LF>WiFi MAC address ec:fa:bc:02:18:54<LF>WiFi Vcc 3.45, reset reason Turned on by main processor<LF>WiFi flash size 4194304, free heap 30176<LF>Socket states: 0 0 0 0 0 0 0 0<LF>ok<LF>
@quilby7 said in Board not connecting to Wifi: no know networks found:
M587
whats the output of just M587? does it include the SSID you added, and is the network a 2.4Ghz network? Any special characters in SSID or password?
M122<CR>
Static ram: 26128
Owned mutexes:
Error status: 4
=== DDARing ===
Segments left: 0
=== Network ===
HTTP sessions: 0 of 8- WiFi -
WiFi module is idle
ok
- WiFi -
@bearer
The output for M587 is:Remembered networks:
Diabase IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
okThe password does have the ! $ @ sybols in it
Looks like I was mistaken. The WiFi Firmware is actually 1.23
I'd try without the
and$
Alright, I'll try that. It's not my personal network so I'll have to contact someone to change it, which may take a while. I'll post back here if it does (or doesn't) work
You may want to try using a macro to add the wifi network. That can avoid any capitalization changes that the USB terminal may do. It's also easier than having to type it a bunch of times.
Something like this saved as a macro called addwifi and placed in the macros folder. Then you can send
M98 P"addwifi"
to execute it.; Add default wifi network ; M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10 M552 S0 ; Disable network module G4 S5 ; wait 5 seconds M587 S"NETWORKNAME" P"PASSWORD" ; Add duet wifi SSID to remembered networks list G4 S5 ; wait 5 seconds M552 S1 ; reenable wifi module M291 R"duetwifi SSID added." P"Check console to verify IP address."
Since the network is not under your control, you could use access point mode to test that the wifi module is otherwise working.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
@Phaedrux
I am trying access point mode currently
I input: M589 S"NetworkName" P"Password" lnnn.nn.nn
It returns: M589: Bad or missing parameter
The WiFi module is Idle. I think that the part I am messing up on is the IP. I am pretty new to this, can the IP be just any random numbers, or is there a format it has to follow? -
Yes you will need to specify an actual ip address.
192.168.0.1 would be suitable.
Example command: M589 S"DuetSSID" P"password" I"192.168.0.1" C1
@Phaedrux
It worked! Not a permanent solution, but it’s good to see some progress. I’ll stil try to get that password changed. Thanks for your help -
@Phaedrux
It worked! Not a permanent solution, but it’s good to see some progress. I’ll stil try to get that password changed. Thanks for your helpHow did you send the password in the M587 command originally? AFAIK the ! $ @ symbols should be OK in a password. OTOH, many GCode sending programs force all characters to uppercase (which will mess up any lowercase characters in the password), also I don't think the WiFi firmware supports accented characters.
@dc42 said in Board not connecting to Wifi: no know networks found:
ah, they were in a warning for SSIDs in the docs, but that doesn't apply to the password then?
Given OP's output from
M587
showing mixed case and no special characters I presumed the issue would be the password, signal strength or frequency band (or could technically still be SSID case sensitivity I guess) -
I was sending the gcode commands using YAT, which I believe can send lowercase characters.
Yes it does, that is why I asked you for the output of M587 with no paramters. It shows the SSID is stored with both upper and lower case so we know you're not using a upper case terminal.
Can you confirm the network is 2.4GHz and that the case is exactly as shown in M587. Duet does not support 5GHz.
I am pretty sure the network was 2.4GHz. I’ll double check with the admin when they change the password. Because of Covid restrictions, it may be a while before I am actually able to test anything out.
