BL-Touch blinking after retract?
that probably means that the grub screw is close enough to cause problems.
but if it is working now..
i personally dont like the bltouch. -
@Veti said in BL-Touch blinking after retract?:
Yes, I will keep an eye on it. The next step will be a calibration if the screw than.
Me neither, but I was not able to find a better solution. I tried the IR-Probe from dc42 and that thing gave me even more problems, so I switched all of my printers back to BL-Touches.
Cheers, Chriss
@Chriss said in BL-Touch blinking after retract?:
i use this on my ender 3
@Veti
I had a ir-probe on my CR-10 pro v2 with a PEI sheet and I was unable to get reliable results. I gave up there after to many crashes of the nozzle to the bed.
The results on my CoreXY with a bright PrintBite+ where also not very reliable. I lost on one of them the IR-Diode, whether by temperature or by a crash. One simply died for "whatever" reason.So I simply gave up, I will give them a next chance sometime in the future but I'm done with them for now.
Cheers, Chriss
sorry i mean to post a link
https://www.thingiverse.com/thing:3303618 -
@Veti
Or V2: https://www.thingiverse.com/thing:3756428That is basically a home made bl-touch if I understand both correctly.
Well, is that technically a better solution? I do not see any benefits here when I compare it with the BL-Touch.
Cheers, Chriss
it has the advantage that if the pin does not drop, probing will fail.
the bltouch will ram into the bed.
its very accurate.
not susceptible to interference.price
its very accurate.
I wish somebody had this ready to buy - I would like to try one.
The problem is back... I think that I need to find a real solution now. Screw?
I think that it must be flush with the top end of the device if my memory is correct here.Cheers, Chriss
If the probe is overwise working you could add the commands to reset errors and retract the pin to the end of config.g and the start of your homing files so that the probe is prepared to be used.
@Chriss Have you updated the boot loader for the 1LC?
https://github.com/Duet3D/Duet3Bootloader/releases -
Well, is that technically a better solution? I do not see any benefits here when I compare it with the BL-Touch.I have both a genuine BLTouch 3.1 and this on a few of my production printers, which run almost all day most days. Believe it or not, the homemade version is faster, more accurate, and has not caused a single inconvenience. Not once in the almost-year that I've used it have I had to tinker with it or worry about it. It just works!
I wish I could say the same about my BLTouch!
@Stephen6309 said in BL-Touch blinking after retract?:
https://github.com/Duet3D/Duet3Bootloader/releasesNot yet.... Can that really make a difference? At the end is the bootloader only loading the firmware... well, I will give it a try.
@Phaedrux Yes, the probe seams to work correctly. The probe is at duty since 3 days and I still work on the hardware. So there is not sooo much to say about the long term experience with that one.
I will update the bootloader and I change the tiny bugger with the one in my CR10 with a duet2, just to know which device is the source.
So it seems that this is not a soooo comon problem.
Cheers, Chriss
It seams that the problem is solved now. I upgraded the bootloader of the toolboard to 2.2. I do not understand how that should have influence here but I'm not a embedded device programmer.
To my future me:
Firmware Update howto:
https://duet3d.dozuki.com/Wiki/Updating_the_bootloader_on_Duet_3_expansion_and_tool_boardsCheers, Chriss
there was a bug that debug information was written to the pwm pin during the bootloader process. this causes problems with bltouch.
@Veti Good to know.
It is a much better solution to fix that than try to work around. The trick with the resets produced a lot of other problems. That seemed to me like a endless process. Anyway, happy now. I'm so happy that I can start with the fist first tests with hot filament.
