Touch-Mi deployprobe.g not working
How are you issuing the M401 command?
just via Console after homing to test it
@Adamfilip said in Touch-Mi deployprobe.g not working:
And you get no movement, no dialog, no errors?
right, nothing happens.
Strange
What firmware version are you using?
If you haven't done this issue M98 P"config.g" and see if you get any errors.
If you haven't done this create a deployprobe.g with just a M291 command to verify that it executed and test M401 against that.
@fcwilt said in Touch-Mi deployprobe.g not working:
M98 P"config.g"
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
Duet WiFi Server Version: 1.25With Just M291 the message does not appear
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Missing Z probe pin name(s) Error: Invalid Z probe index Error: Pin 'fan1' is not free Error: Fan number 2 not found
I'll be right back - I'm going to test something.
OK the error on line 5 is preventing the probe from being configured and thus M401 does nothing.
You are missing the M558 C parameter specifying the input pin.
The error on line 6 may be caused by the M558 I parameter which is not a valid parameter for version 3 firmware
Can you post your full config.g?
Have you seen this? https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Touch_Mi
The M558 needs to be updated for RRF3 syntax as fcwilt indicates.
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M558_in_RepRapFirmware_Num_3
What pin are you using?
Once we figure out the correct syntax I'll update the instructions for the touch-mi to include that. Probably C"zprobe.in"
ok so i will update to the following
M558 P8 C"^zprobe.in" F500 H10 T4000 ; touch me probe
perhaps this guide regarding Touch-Mi should be updated for RRF3
@Phaedrux said in Touch-Mi deployprobe.g not working:
Once we figure out the correct syntax I'll update the instructions for the touch-mi to include that. Probably C"zprobe.in" -
@Phaedrux using ZProbe Pins on Duet2wifi
If you confirm it's working I will update that page.
havent had a chance to test, running some long prints this week
