Touch-Mi deployprobe.g not working
right, nothing happens.
@Adamfilip said in Touch-Mi deployprobe.g not working:
Strange
What firmware version are you using?
If you haven't done this issue M98 P"config.g" and see if you get any errors.
If you haven't done this create a deployprobe.g with just a M291 command to verify that it executed and test M401 against that.
@fcwilt said in Touch-Mi deployprobe.g not working:
M98 P"config.g"
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
Duet WiFi Server Version: 1.25With Just M291 the message does not appear
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Missing Z probe pin name(s) Error: Invalid Z probe index Error: Pin 'fan1' is not free Error: Fan number 2 not found
I'll be right back - I'm going to test something.
OK the error on line 5 is preventing the probe from being configured and thus M401 does nothing.
You are missing the M558 C parameter specifying the input pin.
The error on line 6 may be caused by the M558 I parameter which is not a valid parameter for version 3 firmware
Can you post your full config.g?
Have you seen this? https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Touch_Mi
The M558 needs to be updated for RRF3 syntax as fcwilt indicates.
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M558_in_RepRapFirmware_Num_3
What pin are you using?
Once we figure out the correct syntax I'll update the instructions for the touch-mi to include that. Probably C"zprobe.in"
ok so i will update to the following
M558 P8 C"^zprobe.in" F500 H10 T4000 ; touch me probe
perhaps this guide regarding Touch-Mi should be updated for RRF3
@Phaedrux said in Touch-Mi deployprobe.g not working:
Once we figure out the correct syntax I'll update the instructions for the touch-mi to include that. Probably C"zprobe.in" -
@Phaedrux using ZProbe Pins on Duet2wifi
If you confirm it's working I will update that page.
havent had a chance to test, running some long prints this week
