How can I control the moves taken after tpost#.g?
Are you doing the X and Y restore?
I don't see anything in the docs for changing tools that talks about position restoration.
@fcwilt I'm 99% sure I'm not, it's just what happens naturally once a print resumes, the tool head has to move into position to start printing.
Checking.
@gnydick said in How can I control the moves taken after tpost#.g?:
Please post your pause.g and resume.g files using the </> tag
That is where I have the commands that control position restoration.
pause and resume aren't used during tool changes. I've even gone so far as to manually store and retrieve the positions, and nothing happens when I click through the dialogs
;tfree#.g G91 G1 Z20 G90 M291 S2 P"About to store the position" G60 S0 ; save the current position M291 S2 P"Just stored the position"
;tpost#.g M291 S2 P"About to restore the position" G1 R0 ; restore the current position M291 S2 P"Just restored the position"
OMG --- I just looked at what was generated in the resume.g. That's my answer!!
From the G60 docs:
Slots 0, 1 and 2 are available. When a print is paused the coordinates are saved to slot 1 automatically, and at the start of a tool change the coordinates are saved to slot 2 automatically. Use G0 or G1 with the R0, R1 or R2 parameter to move the current tool to a saved position.
It mentions the position being saved automatically to slot 2 but it says nothing about automatic restore.
You said resume.g was not involved.
Confused.
@fcwilt it gave me an example of how to use the
R
parameter properly withG1
@fcwilt, EVERYONE, et al
So, here's a summary of the behavior.
Without using
G60
in my tool changing scripts, the print resumes by moving to the next position in the gcode. That is where the newly current tool will start. This changes Z, then moves to the XY, rubbing the print. -
With using
G60
in mytfree#
tool changing scripts, the print resumes at the last position of the previous tool. That is bad, as I don't want the tool to come down over the previous traces.
So, I want the XY progression from #1, since it moves to the first position of the new tool, but I don't want it to change Z first, then slide into the print area.
Does this make sense?
I understand what you are saying but having never used a multi-tool printer I don't understand why it is needed.
Is the tool change tied to a layer change?
So none of the abilities mentioned here regards using G1 with R can get you what you want?
Rn Return to the coordinates stored in restore point #n (see G60). Any X, Y, Z and other axis parameters in the command are used as offsets from the stored position. Axes not mentioned are not moved, so use offset 0 for axes you want to restore to the stored value. For example, G1 R0 X0 Y0 Z2 will move to 2mm above the position stored in restore point 0.
No, it's not what I want. Let's say I'm printing in RED, I change tools to BLACK. Even if I'm using G60 with a Z offset, then when
G1 R0 X0 Y0 Z15
the BLACK tool will move to 15mm above the last RED position, and when that's finished, it still lowers all the way down to whatever the correct Z position is for the next move, before moving XY to the first BLACK position.That in a nutshell is what I can't seem to defeat. The "let me lower all the way down before moving XY" behavior.
As @fcwilt says, you can achieve the result you want using restore point 2. For example:
G1 R2 Z2 ; move to 2mm higher than the restore position
G1 R2 X0 Y0 Z2 ; move to 2mm above the restore position -
@dc42 that doesn't work
G1 R2 Z2 moves 2mm above the last position, but then the Z height lowers to the restore point, then XY to the first BLACK point
G1 R2 X0 Y0 Z2 only additionally moves over the last point first.
Either way, the Z is changed FIRST to the next point, which is bad. It will always wipe the print.
@dc42 that doesn't work, because the restore position is the last RED position. And after G1 R0 (or R2) happens, the Z height lowers down to the print, then XY moves to the first BLACK position.
What I don't understand is this.
Why doesn't BLACK need to start extruding at the last RED position?
If it was a single color with no tool changing/pausing there would be extrusion between the two points - not a gap.
@fcwilt because it's two different objects. Why would black start where red left off?
Well that makes a world of difference.
So back to a single extruder setup.
It would reach the end of the first object - stop extruding - move to the next object and start extruding. Correct?
So does it matter if it changes extruder before moving to the next object if it has already stop extruding?
@fcwilt with a single extruder, if it's "changing" tools like a filament swapper, yes, it's still a separate object (depending on the slicer).
I like to use the "separate shells" option which provides full perimeters, tops, and bottoms on the different objects.
I see, you want to change tool and then resume position at the start of the next printing move, not the start of the travel move from the old part being printed to the new part. The problem here is that when RRF executes the T move, it hasn't processed the following G0 or G1 moves (or any other moves that might come first), so it doesn't know whether the next move starts printing immediately or not.
If you know that after a tool change there will always be a travel move before the next printing move, then you could try using G60 in the tpost file to store the XY coordinates of a point away from the print, along with a Z coordinate higher than the print, to restore point 2. Then it would move to that position after a tool change.
