Duet Wifi V1.01 SD Card
I need to install firmware and configuration files on a SD card for my Duet Wifi V1.01. I have looked through a number of posts and have not had luck. Is there a nice, easy to follow, procedure for loading firmware/config files on the SD card? All posts I have come across have a number of links with a number of different configurations. Is there a zip file I can DL and cut and paste to the SD card to get started?
Here is a loose guide on getting a config set from the online tool, preparing the SD card, and flashing the firmware, and getting connected.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
@Phaedrux Thank you for the info. I made progress but now I get a "Wifi module is being started" when I put in the M552 command. I used the link provided in the instructions and downloaded the Duet2Firmware-2.02b and put in the Duet2CombinedFirmware.bin and DuetWifiServer.bin into the sys folder on the SD card.
Update.
Able to follow instructions up the point where I need to put in my network name and PW using M587 command, but nothing happens. Wifi just stays in idle mode.
@paulyp45 This one may help more for setting up wifi access:
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7?lang=en#s10After you've added the wifi username & password with
M587
, you then need to put the wifi module back into active mode by sendingM552 S1
Once you get connected to wifi and have access to DWC, upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
That will get your firmware and DWC up to date.For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/Start
