Solved Duet3 6HC not deploying BL touch for mesh bed leveling
@fcwilt wait...? are you saying it should just read M574 Z1? no s parameter or P parameter?
@autopilot-exe said in Duet3 6HC not deploying BL touch for mesh bed leveling:
A M574 is not needed for configuring a Z probe.
If you don't have a Z endstop sensor you would have M574 Z0.
If you do have a Z endstop sensor then you use M574 Z(1 or 2) S1 and specify the input pin name.
In your case your were trying to use the same input twice - which you cannot do.
@fcwilt so I commented it out to test.
good news: the probe still deploys for homing Z.
Bad news: the probe macros are all non responsive now and the mesh bed leveling still fails to deploy the probe -
Bad news: the probe macros are all non responsive now and the mesh bed leveling still fails to deploy the probeJust FYI you don't have to post screen shots - you can copy and paste code right into a </> tag.
If the probe deploys for homing it should deploy everywhere - unless something is configured wrong.
Do M401 and M402 always work?
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 05 2021 11:02:45 GMT-0600 (Central Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-605 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-605 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 05 2021 11:02:46 GMT-0600 (Central Standard Time) G91 ; relative positioning G1 H2 Z15 F6000 ; lift Z relative to current position G1 H1 Y-555 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-555 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-10 F6000 ; lower Z again G90 ; absolute positioning
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 11:26:03 GMT-0600 (Central Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X163 Y161 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
; homec.g ; called to home the C axis (coupler) ;crashc G92 C260 M913 C40 ; C MOTOR TO 40% CURRENT G1 C-260 F2400 ; drive the C-axis to the stop M913 C100 ; C MOTOR TO 100% CURRENT G1 C1 F50000 G92 C0 ;Open Coupler M98 P/macros/Coupler - Unlock
note: the homec.g file was directly copied from e3d's documentation.
According to the docs M98 requires double quotes around the file name in v3 firmware.
@fcwilt the duet doesn't spit out any errors. I typed "m401" and I get a green notification, but nothing moves on the machine. I type "m402", same thing happens.
Can you confirm that your deploy and retract probe macros are in the /sys folder?
@fcwilt in my homeall.g there are quotes around the file names. Home C,X, and Y are all executed correctly. when it gets to home z, the probe still doesn't deploy. I just tried it after removing the M574 command earlier.
Can confirm.
Hmm...
At this point I suppose we should verify the contents of deployprobe.g and retractprobe.g.
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 11:26:03 GMT-0600 (Central Standard Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 11:26:03 GMT-0600 (Central Standard Time) M280 P0 S90 ; retract BLTouch
Does the probe run it's self-test routine when you power on the printer?
Did you verify that it is connected to the correct input and output pins?
@fcwilt the self test is working, I have it wired correctly according to the documentation. (3.3v: nothing, io7.in: white, GND: black and brown soldered together going to a single pin, io7.out: orange, 5 volt: red)
Running out of ideas.
I have a Duet 3 setup on my workbench and BLTouch units in inventory.
All boards (6HC, 3HC, 1LC) are running 3.2.2.
I will get a BLTouch out and connect and configure as you have.
@fcwilt A possibility that I just considered: the firmware generator tool that I used as a base is v3.2.3. Could the mismatch be from there? i.e, the RepRapFirmware Configuration tool version not being in line with the firmware version?
@autopilot-exe , what version is your Duet 3 6HC board?
In the tool you can select the firmware version you want it to generate a config for. The exact version of the config tool isn't important really.
Can you post a photo of the wiring?
io7 should be ok unless it's a prototype board.
@dc42 hey, its labeled as V1.0
I installed the most recent version of a BLTouch on my 6HC board (running 3.2.2) at IO7.
I powered it from 3.3 volts.
These were the configuration commands:
M950 S0 C"io7.out"
M558 P9 C"io7.in" H2 F120 T9000 R0.2 A1 S0.01 ; 1 readingM401 worked. M402 worked. G30 worked.
