One axis will not calibrate
Please post your config.g file using the </> tag.
Also tell us what board you are using and what firmware version.
; Configuration file for Duet WiFi (firmware version 2.00)
; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 01 2021 20:16:34 GMT-0500 (Eastern Standard Time); General preferences
M550 P"SD4" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M350 Z16 I0 ; configure microstepping without interpolation
M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
M92 X90.36 Y88.78 Z2151.90 E415.00 ; set steps per mm
M566 X1000.00 Y1000.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X2000.00 Y2000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E250.00 ; set accelerations (mm/s^2)
M906 X1050 Y1000 Z1050 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S5 ; Set idle timeout; Axis Limits
M208 X203 Y203 Z203 S0 ; set axis maxima; Endstops
M574 X2 Y2 Z1 S1 ; set active high endstops; Z-Probe
M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:203 Y15:203 S20 ; define mesh grid; Heaters
M143 H1 S285 ; set temperature limit for heater 1 to 285C; Fans
M106 P1 S1 I0 F500 H1 T23 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M564 H0; Miscellaneous
M501 ; load saved parameters from non-volatile memory -
I've re-posted your config.g file using the </> tag as requested.
thunderboltcutter Mar 19, 2021, 2:58 PM ; Configuration file for Duet WiFi (firmware version 2.00) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 01 2021 20:16:34 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"SD4" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 Z16 I0 ; configure microstepping without interpolation M350 X16 Y16 E16 I1 ; configure microstepping with interpolation M92 X90.36 Y88.78 Z2151.90 E415.00 ; set steps per mm M566 X1000.00 Y1000.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X2000.00 Y2000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E250.00 ; set accelerations (mm/s^2) M906 X1050 Y1000 Z1050 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S5 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X203 Y203 Z203 S0 ; set axis maxima ; Endstops M574 X2 Y2 Z1 S1 ; set active high endstops ; Z-Probe M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height M557 X15:203 Y15:203 S20 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S285 ; set temperature limit for heater 1 to 285C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T23 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings M564 H0 ; Miscellaneous M501 ; load saved parameters from non-volatile memory
Thank you!
I don't see anything obvious there.
From the DWC console execute M122 and post the results.
Also execute M98 P"config.g" and let us know if there are any warnings or errors reported.
I am getting a spam error when trying to post M122 output to the forum. Is there a work around?
@thunderboltcutter said in One axis will not calibrate:
Change the file extension to .g perhaps?
@fcwilt
I am going break things up into a few posts to see what's getting caught by the filter.~~M98 P"config.g" HTTP is enabled on port 80 FTP is enabled on port 21 TELNET is enabled on port 23~~
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later Board ID: 08DLM-996RU-N85S4-7JTDL-3SN6R-1S9VR Used output buffers: 1 of 20 (19 max) === RTOS === Static ram: 28380 Dynamic ram: 95820 of which 0 recycled Exception stack ram used: 420 Never used ram: 6452 Task NETWORK ready, free stack 324 Task HEAT blocked, free stack 1256 Task MAIN running, free stack 3624
For some reason my Y axis will not respond to changes in the config.g file. When I print a calibration cube that side always comes out the same.
What exactly does this mean? I'm not sure what you're describing. Photo of the results? What are you expecting to happen? What are you trying to change?
I've given you a few upvotes, so hopefully it won't bug you about spam as much. Might also help to take a pause for 10 minutes and try and create a single post again with all the copy and paste. Multiple posts in rapid succession is likely to trigger it.
@Phaedrux said in One axis will not calibrate:
I learn something new everyday.
No matter what I do with the y axis variable when printing a calibration cube I get 20.55mm from that side.
Using setting like this yields the same results:
M92 X90.36 Y91.0 Z2151.90M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later Board ID: 08DLM-996RU-N85S4-7JTDL-3SN6R-1S9VR Used output buffers: 1 of 20 (19 max) === RTOS === Static ram: 28380 Dynamic ram: 95820 of which 0 recycled Exception stack ram used: 420 Never used ram: 6452 Task NETWORK ready, free stack 324 Task HEAT blocked, free stack 1256 Task MAIN running, free stack 3624 === Platform === Last reset 05:29:33 ago, cause: power up Last software reset at 2021-03-18 20:25, reason: User, spinning module GCodes, available RAM 6588 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 25.5, current 25.5, max 25.8 Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0 Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2021-03-19 15:06:44 Slowest loop: 7.60ms; fastest: 0.08ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.8 Heater 1 is on, I-accum = 0.4 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is ready with "M122 " in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 200.85ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 2 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 3, notready 0, noresp 3 WiFi firmware version 1.25 WiFi MAC address f4:cf:a2:69:48:de WiFi Vcc 3.33, reset reason Turned on by main processor WiFi flash size 4194304, free heap 23104 WiFi IP address 192.168.1.82 WiFi signal strength -56dBm, reconnections 0, sleep mode unknown Socket states: 0 0 0 0 0 0 0 0 === Expansion ===
M92 X90.36 Y91.0 Z2151.90Where did you get those values? They are a bit unusual.
Perhaps you could restore the X and Y values to the theoretical values and using...
M579 X1.0 Y1.0 Z1.0 ; scaling (values are determined by measuring test object)
to scale the size of the objects printed? Values of 1.0, as shown, produce no scaling.
@fcwilt said in One axis will not calibrate:
Looks like the solid doodle uses MXL belts and 17 tooth pulleys for an approximate steps per mm of 88.
http://www.soliforum.com/topic/2671/solidoodle-belt-and-pulley-specs-belt-replacement-guide/page/2/
https://tomhorsley.com/hardware/solidoodle/solidoodle-calibration.html
Can I get you to update your firmware?
Upload this zip file to the system tab in DWC.
Don't extract it first.
Never heard of MXL belts or 17 tooth pulleys - new facts to stuff into my old brain.
One thing I don't quite understand is why the X and Y steps/mm (whatever they actually should be) would in practice be different.
What is the source of the variation between X and Y?
Well Solid Doodle made some funny choices. (MXL, 17 tooth, etc) so who knows what else is funky in there. Product of the times I suppose.
As for why they would be so different here in this case and why the steps per mm isn't having an effect, I wonder if it's something mechanical. Slippage or something. Loose grub screw?
