Solved DWC global object populated but not updated DWC v3.3b3
Just updated to 3.3b3.
I have numerous global variables defined in config.g and many of these are changed from time to time.
As per the topic, the global variables are populated in the DWC object model but they do not automatically update like other object model vales.
Nor do they update if you hit the REFRESH button at the bottom of the page.
You have to fit F5 and refresh the whole page to have it update.Not the end of the world, but may cause confusion as everything else seems to now auto-refresh.
@owend said in DWC global object populated but not updated DWC v3.3b3:
Yes, we discovered this at the very end of the release testing, but decided not to hold up the release. We will fix it before the next release, which will probably be either 3.3RC1 or 3.3 final release.
I'll mark as solved given the low impact and the fact the dev's have it in hand.
