Solved Rostock upgrade commissioning issues
I've just recently upgraded my Rostock Max V2 with a Duet3D 2 Wifi, SmartEffector and an E3D v6 hotend. I'm having difficulty getting the steppers to move after homing. Once the homing completes, the endstops are engaged and the steppers are energized preventing free movement. I can use G1 H2 X(Y,Z)-10 to move each axis by ignoring the endstops, but I am unable to get G30 to work for the bed leveling as I don't know how to get the G30 to ignore the endstops in order to move. Any assistance would be greatly appreciated.
Here are my M122 after homing, config.g, homedelta.g, and bed.g.
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MS8-6J9FA-3SN6L-TSVH9
Used output buffers: 3 of 24 (14 max)
Static ram: 23460
Dynamic ram: 72644 of which 60 recycled
Never used RAM 15916, free system stack 121 words
Tasks: NETWORK(ready,171) HEAT(blocked,308) MAIN(running,463) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:10:55 ago, cause: power up
Last software reset at 2021-07-02 12:00, reason: User, GCodes spinning, available RAM 15928, slot 2
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 22.6, current 30.8, max 31.2
Supply voltage: min 13.5, current 13.6, max 13.8, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position -160, standstill, SG min/max 0/70
Driver 1: position -160, standstill, SG min/max 0/114
Driver 2: position -960, standstill, SG min/max 0/416
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-07-03 08:40:50
Cache data hit count 796970581
Slowest loop: 15.97ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.1ms, write time 7.2ms, max retries 0
DMs created 83, maxWait 283368ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 12, completed moves 12, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 25.61ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address a0:20:a6:32:42:ab
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26640
WiFi IP address 192.168.1.10
WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
; config.g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 11:59:07 GMT+0900 (Japan Standard Time); General preferences
M550 P"Minathevi 3Delta" ; set printer name
M665 R310 L304.14 B280 H318.5 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E84.88 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1300 Y1300 Z1300 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
M557 R85 S20 ; define mesh grid; Heaters
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M308 S1 P"e0temp" Y"thermistor" T100000 B4388 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
T0 ; select first tool
; homedelta.g
; called to home all towers on a delta printer
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 12:00:33 GMT+0900 (Japan Standard Time)
G91 ; relative positioning
;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
G1 H1 X445 Y445 Z445 F180 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre; bed.g
; called to perform automatic delta calibration via G32
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 02 2021 12:01:10 GMT+0900 (Japan Standard Time)
; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y279.9 H0 Z-99999
G30 P1 X242.4 Y139.95 H0 Z-99999
G30 P2 X242.4 Y-139.95 H0 Z-99999
G30 P3 X0 Y-279.9 H0 Z-99999
G30 P4 X-242.4 Y-139.95 H0 Z-99999
G30 P5 X-242.4 Y139.95 H0 Z-99999
G30 P6 X0 Y139.9 H0 Z-99999
G30 P7 X121.16 Y69.95 H0 Z-99999
G30 P8 X121.16 Y-69.95 H0 Z-99999
G30 P9 X0 Y-139.9 H0 Z-99999
G30 P10 X-121.16 Y-69.95 H0 Z-99999
G30 P11 X-121.16 Y69.95 H0 Z-99999
G30 P12 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed) - WiFi -
I don't think it's a case of the endstops being engaged and preventing movement. The endstops are only active during a G1 H1 move.
G1 H1 X445 Y445 Z445 F180 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
After that first homing pass to the carriages back off 5mm and then home again?
Do you get an error message when you try and use G30?
@phaedrux The carriages do back off 5mm and home again.
When attempting the bed leveling the error I get is "Z probe not triggered during probing move", but the effector doesn't move at all. I've fiddled with bed.g before to see if it's even trying to do anything by adding a homing move before and after all of the G30 probing moves and it completes them just fine. I just can't get it to attempt to move to the bed for probing. I've gone through the commissioning of the smarteffector and have confirmed that I do in fact get a green LED when tapping on the hotend and I do see the z probe readout change in the DWC when tapping. I'm sure it isn't an effector issue and I've eliminated the steppers and stepper drivers as the issue since the carriages move when homing. I can also move them independently with G1. Something I haven't been able to do is move all three carriages at the same time for a Z-height move. I'm not sure why. Any time I attempt a G1 Z move it only moves the Z tower carriage instead of all three.
@minathevi I think you are saying that homing completes but the machine doesn't respond to normal move commands after homing (only to G1 H2 moves). Is that correct? What XYZ coordinates are displayed in DWC or returned by M114 after homing?
PS I think I see the problem, in your M665 command. You have set the delta radius larger the the rod length, which is an impossible configuration.
@dc42 Wow. I'm an idiot. I didn't read the RepRap configurator closely enough and entered the diameter instead of the radius. Homing and bed leveling work as intended. I'm amazed at how long I've been banging my head against the wall on this one.
Thank you for your help.
Now to figure out why my extruder stepper doesn't seem to work.
@dc42 Nevermind. I figured out the extruder. Tool 0 has to be active for the extruder motor to energize.
Thanks again for the help!
