Auto Calibration of Nozzle Z offset
I'm using FLY RRF-E3 board and RRF 3.0 firmware, when configuring Z offset auto calibration, I met some issue. it shows below error when send "G30 K1 Z-9999", anyone know what's the reason? thanks!
I connect Z switch to below position
here is setting in Config.g
From the DWC console execute M98 P"config.g" to see if any errors are reported.
@nicolas-brejat can you run M98 P"config.g"
Can you also post your full config?
PC5 is the same as zstop. Can you also make sure zstop isn't used in your config -
@fcwilt ok, here is the error it reported
@jay_s_uk ok, here is full config for your reference:
M550 P"My Printer" ; set printer name
M669 K1
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards using default driver timings
M569 P1 S0 ; physical drive 1 goes forwards using default driver timings
M569 P2 S1 ; physical drive 2 goes forwards using default driver timings
M569 P3 S1 ; physical drive 3 goes forwards using default driver timings
M92 X80.00 Y80.00 Z400.00 E140.00 ; set steps per mm
M906 X900 Y900 Z700 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X260 Y210 Z200 S0 ; set axis maxima; ---filament sensing---
M591 D0 P1 C"PA13" S1; Endstops
M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input; Z-Probe
M558 P5 C"probe" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z3 ; set Z probe trigger value, offset and trigger height
M558 K1 P8 C"PC5" T18000 F180 H2.4 A10 S0.0025 R0
G31 K1 P500 X0 Y0 Z-0.5; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S350 ; set temperature limit for heater 1 to 350C; Fans
M106 P1 S0 H1 T50 ; set fan 1 value. Thermostatic control is turned on; Tools
M918 P1 E4 F1000000
M501
M500
M851 -
@nicolas-brejat said in Auto Calibration of Nozzle Z offset:
I tested configuring two probes as you have done but it was under firmware 3.3.0
Perhaps something is different under your firmware.
Did you try including the parameter K0 for the first M558/G31 commands?
@fcwilt do you mean it's workable under firmware 3.3.0? I'm using RRF 3.0 now, if change K1 to K0 in M558/G31 command, the "K too high" error will disappear, but K0 is for leveling probe, so it'll have below error when auto home:
G31 K1 P500 X0 Y0 Z-0.5he meant add K0 to the first M558.
can you post the output of M115? we never released a version of RRF3.0 for the Fly-E3 -
@jay_s_uk it was RRF 3.0 before, just now updated to 3.3, but still same issue.
@nicolas-brejat ok, thats still not the latest release.
Please find the latest release here https://github.com/gloomyandy/RepRapFirmware/releases/tag/v3.3_2 -
@jay_s_uk after update below firmware, the LCD 12864 screen becomes blank, Wifi fail to connect. does it need to change other settings after update 3.3.2 firmware?
@Nicolas-Brejat No. You've loaded the incorrect file. You should be using the ESP8266wifi file and not the SBC file.
@jay_s_uk ok, still same error. so it's not related to firmware version?
@nicolas-brejat one for @gloomyandy
@jay_s_uk We only currently support a single probe.
@gloomyandy do you mean RRF firmware doesn't support 2nd probe? if change to duet board, will it work?
@nicolas-brejat the STM port currently doesn't support more than one z probe (mainly as a hang over from all the restrictions initially made to the LPC port) but the duet boards do.
It has been added to the to-do list to investigate increasing that limit as part of the next release. -
@jay_s_uk ok, that make sense. hope next release will fix that. thanks
