Input shaping
Hi. I have version 3.3. I have really small ghospting when printing fast and I would like to try the DAA. In the docs I found:
Divide the speed at which the outer perimeter was printed (in mm/sec) by the distance between adjacent ringing peaks (in mm).
My question is: the speed I ise in the calculation is the speed set on the slicer o the real speed. Because on the screen I can see "requested speed" and "top" speed" Top speed I gues is the real speed used in that movement because the requested speed is something not always posible to reach due lenght/accel settings
Which speed should I use?
@tinchus it should be the real speed used. However, unless you set acceleration very low, then for any straight wall that is 5mm or longer it's unlikely that the actual speed will be lower than the requested speed.
@dc42 Thanks!
