Solved M584 help needed
Enter M669 from the DWC Console and see what it reports.
These are mine but I had to do some trial-and-error to get the right values for X and Y.
M669 X-1;1;0 Y-1;-1;0 Z0;0;1 ; CoreXY via matrix values (the ; need to be : but posting with them is messed up)
I believe the X and Y values will always be of the form #:#:0 where the #s are either 1 or -1.
Do you have M669 K1 in your config already?
@phaedrux no
Then add it near the start of config.g to set the kinematics type to core xy.
@phaedrux actually yes I do. Says m669 k1. Nothing after that
@phaedrux What should it say after K-1
@jlee73 said in M584 help needed:
I don't know what you mean by k-1
Are you sure you have the motors connected to the right drivers?
You can also try the explicit matrix shown by @fcwilt -
@phaedrux the line says m669 k1. Nothing after that
Yes, K1 is corexy mode. It doesn't need more after that. And by the looks of your screen shot when you sent M669 by itself it does report that it's in corexy mode. So that seems correct. Which is why I ask if the motors are all connected to the expected drivers.
The problem is once I have homed everything X moves fine, but when I tried to move the Y axis the Z motors also move.
How much z movement are you seeing exactly?
Can you post your homing files? Your entire config.g would also be good. And for good measure can you send M122 and M98 P"config.g" in the gcode console tab and copy and paste the text here?
M98 P"config.g"
Error: in file macro line 14: M540: invalid MAC address
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Debugging enabled for modules:
Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16) CAN(17)
Warning: Macro file config-override.g not found -
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Apr 26 2022 14:49:38 GMT-0600 (Mountain Daylight Time); General preferences
M550 P"Beast" ; set printer name
M669 K1 X1:1:0:0 Y10:-1 Z0:0:1:0 ; select CoreXY mode; Network
M551 P"Neiljess18" ; set password
M540 P0.0.0.0 S1 ; set custom MAC address
M552 P192.168.1.129 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M584 X0.0:0.1
M584 Y0.3
M584 Z0.4:0.5
M584 E0.2 ; set drive mapping
M92 X400.00 Y400.00 Z3.00 E611.15 ; set steps per mm
M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X2500 Y2500 Z2500 E2000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X965 Y400 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
;M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
G21
M111; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@phaedrux
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-970 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-970 ; home X axis
G1 H1 Y-405 ; home Y axis
G1 H1 X-970 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-405 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
@phaedrux
; homex.g
; called to home the X axis
G1 H1 X-970 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
G1 H1 X-970 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)So as part of your homing files it lowers the Z axis for clearance before moving in XY. Is that what you're seeing? if so, this is normal. If not, please post a video.
@phaedrux
; homey.g
; called to home the Y axis
G1 H1 Y0 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y0 F360 ; move slowly to Y axis endstop once more (second pass)
@phaedrux
; homez.g
; called to home the Z axis
G1 X15 Y15 F6000 ; go to first probe point
No, once everything is homed on dwc, i then try ti use the move "y" by 1,10 or 50 buttons to move the y which is my hotend. when i do that the x axis also moves it should not move at all.
@jlee73 it has nothing to do w Z
The corexy kinematic uses both motors to produce motion. Only 45 degree moves would use a single motor at a time. Is this what you're seeing?
Again, can you post a video so we can see what you're seeing?
