AMB Milling Motor & Duet3 MB6HC
@nightowl999 said in AMB Milling Motor & Duet3 MB6HC:
OK, @fcwilt. Thanks again
Let us know how it all goes.
@fcwilt Fear not, I will!
One last thing before I sink myself into a comfy chair... all the GND connectors on the Duet boards are common and connected to each other, are they not?
This might make connecting things a little easier.
Yes GND is GND but they may not all have the same current carrying capacity. A GND for a power connection will likely use a wide copper trace (or two) on the PC board to carry more current. A GND for a signal connection will likely use a narrow copper trace due to lower current carrying requirements.
So choose your GND connections carefully.
@fcwilt
I was thinking more about the milling motor, as the brown cable connects to the VIN of the Duet power supply pin, and there is also a link between the white cable to the GND of the converter, I was thinking it would be better to connect the brown and white directly to the PSU. -
@nightowl999
If you mean have two wires carrying power to the Duet and another two wires carrying power to the motor - yes, that is what I would do.
I might even consider using a second power supply just for the motor. Now I don't know anything about your particular motor but some motors can generate damaging voltage spikes under certain circumstances. If a second power supply was used the Duet board would be isolated from any possible spikes.
That's pretty much hos it's explained in the pages you liked to above:
- Brown to βVINβ connector of the duet power supply pin
- White to port 5 β voltage output β (GND)β of the pwm converter
- Connect port 5 β voltage output β (GND)β of the pwm converter to the βGNDβ pin of the power supply on the duet board
There's no problem if you want to run:
- Brown to βV+β connector of the duet power supply
- White to βGNDβ of the duet power supply
In practice then, Pins 4 and 5 on the converter, the White cable on the milling motor, and the two GND pins on OUT9 2+3 cluster are all common to each other (I get the pins of OUT9 may be narrow copper strips in the PCB).
What I'll probably do is use Wago connectors as a GND and +VE bus for the relevant power supplies and go from there.
The only thing I need to be sure of is which of the OUT-9 pins I can use for the DIN+ve and DIN-ve (Ports 1 and 2) of the converter.
OUT 9 only has two pins really - VOUTLC2 and OUT9. The two other connectors you mentioned previously are not relevant for your needs.
VOUTLC2 would connect to DIN+ and OUT9 would connect to DIN-.
Thank you, @fcwilt.
Once again, your help and that of @alankilian is much appreciated!
All the best!
Thank you, @fcwilt.
All the best!
Glad to help when I can.
