Ran two good prints now Z axis grinds while trying to go down.
and the axis, does it run freely?
yea when i move it myself it runs ok.. like up and down but when its plugged in it shakes when it starts.
I bit more effort: change stepper controller assignment between z and X or Y *). But in most cases it will be mechanical, I think. All pulleys are fixed? (especially the silver one between stepper and trapezoid)
*) edit to check whether the stepper controller on the board is ok
The trapezoid at the top could hang, also.
Are the steppers stuttering if they are disconnected from the mechanics?
So its got to be the board . I ran two seperate motors from the same ports on z axis and they did the same thing. Stutter. I changed the wires and still stutter..
I have only two ideas left: motor controller too high current setting (or too low), and cabling somehow wrong. Sorry, then I cannot help further.
I tested the with a multi meter for 1a 2a coils and 2a 2b coils are all good. I ran a print that was successful already so thats out of the question.. hmmmm.. the current is at 800MA
In Video
https://www.youtube.com/watch?v=wQBItwXSK3g
in comments sections, the solution was to replace the board. -
Yea its with the board. all axis work fine but anything plugged into the z axis is just not getting the right current which is making both motors stutter. Im going to run down to my shop and show them the problem .
I had already to replace my paneduet 7i as well
Good luck with fixing this!
What is the specification of the Z stepper motors on the CR10? If they are low current high inductance motors, they may need to be connected in parallel instead of in series (the Za and Zb motor connectors are wired in series).
