steppers with lots of Amp... + M906 command
@wilriker
Oops - hopefully fixed now - please check again! (Learned: Do not copy what is in field of openoffice-calc by just clicking on the field and (on windows) press ctrl+c but rather select what is in that field first and then press ctrl+c...) -
@lb said in steppers with lots of Amp... + M906 command:
What it misses for my setup to be of a value:
-> Reduction ratio that I seem to have to use on this setup (since reduction is going with "/ ratio^2" for inertia but only "/ratio" in speed very important in my understanding)
https://pdfs.semanticscholar.org/f1d3/f1eee2a1a3380eb5cdbc3a605a21c6058bfd.pdf
& with a formula for belt-driven-systems:
https://www.motioncontroltips.com/faq-how-do-i-calculate-the-inertia-of-a-servo-driven-system/-> Inertia of motor-shaft-clamped pulley-wheel or whatsoever on motor should be added-able to the motor-inertia
I just looked at the second links with the formulas. I don't think that this matters too much. Because usually the mass of belt and pulley are negligible compared to all other masses in play. I don't think it makes sense to add 10-50g to even 500g axis (although it lowers the acceleration a bit). It won't have a large effect but makes the number of input fields in the calculator a lot more.
But maybe I shouldnยดt be so worried about all that
I have a feeling that you are dead right with this assumption.
P.S.: I think I will add gear ratio to the Advanced Settings.
@wilriker
cool! Looking forward to itCan anybody help me for my "open-office-calc"-sheet for the motors how to convert the given g cm^2 from the motor to put into perspective J for comparison... or do I get it right when J = g*cm^2 ?
@lb OK, gear ratio is now added under Advanced Settings.
About your question on how to convert g cmยฒ into J. In the online calculator this is done the following way:
rotorMass = (motorCount * rotorInertia) / (pulleyRadius * pulleyRadius) / 1000.0;
Is that what you asked for?
@wilriker
Thanks!To be honest all that is so new to me, that I do not know if it is what I am looking for - that said - I am realizing, what I am looking for is how to convert what is given in most datasheets for steppers to what I need to put into the "inertia-match"/"inertia-ratio" formulas, so if I take your formula I have a few questions:
- rotorMass? -> In gramm (you divide by 1000 in the end)
- motorCount? -> rpm or rps? Or what else?
- pulleyRadius? -> Of which pulley, the "main" pulley?
At least a first thread I can maybe follow down the road...
Don't worry, so it is to me. I am learning as I go - and usually I create online calculators along the way and learn more by the feedback I get for these.
Can you be a bit more specific on that? Stepper data sheets contain a lot of values.
The result is of course in kg. Relevant here is rotor inertia which is given in the datasheet of stepper motors as g.cmยฒ.
This is for the case where you have multiple motors driving the same axis as in CoreXY machines. This really is the count of motors.
The pulley fixed to the motor shaft.
@wilriker said in steppers with lots of Amp... + M906 command:
Can you give me a formula how to calculate the inertia of a drive pulley? I know how to do it for the rotor inertia based on the value given in the datasheet. If this is based on the pulley's diameter this could even be added easily without another input field.
Rotational mass would be diameter x "length" correct? Some people run 6mm belts and some run 9mm belts. Maybe others as well.
Maybe too trivial to worry about...
@danal From what the OP added as resources via links this was actually the inertia added by the mass of the pulley and belts themselves. Those 10 to 50 grams.
rotor-inertia given in g cm^2 -> "J" for ratio
sounds good with g cm^2
Oops sorry for that question
But what if there is a small pulley going from the motor to a "main"-shaft that has a ratio? -> What pulley then? Say 25,465mm r(-motor) to 14,006 r(-mainshaft) (gear-ratio of 1,818) -> Pick the one where the load is driven from?
@wilriker
do not make the same mistake as I did: If there is a reduction/adduction (gear-ratio) of the motor involved the NM of the Motor is (de-)amped by the amount also... -
To calculate that you need the radius of whatever is attached to the motor shaft and then in insert it into the formula a bit further above (and I think it also is on that page you linked with all these formulas).
Something doesn't add up here. First you say a small pulley in to motor and then in your example the small pulley is the larger one. Anyway, radius or diameter is not the base of gear-ratio (even though in most cases it comes close) but interacting number of teeth of the different gears. Then again the gear ratio on my calculator expects rotation on the motor : rotation on the load. I will fix this later.
In your example this would mean your gear ratio is 1:1.818 since one rotation of the motor shaft leads to 1.818 rotations of the load shaft as far as I can tell from your description.@lb said in steppers with lots of Amp... + M906 command:
I don't think I can follow you here. Why would adding gearing reduce or increase the motor torque? It will of course affect the torque that is applied on the load but the motor does not change. What am I missing?
First: Thanks for coming back on this!
-> Thanks! So this is exactly that point where we "add" the wheel attached to the motor to the rotor inertia? Canยดt we just sum up the motor-inertia + the attached wheel-inertia for that? For what do we need the rotor-mass in Kg?
In your example this would mean your gear ratio is 1:1.818 since one rotation of the motor shaft leads to 1.818 rotations of the load shaft as far as I can tell from your description.-> These were just examples, will pick one example for this post to ease communication... You understood the "last" example perfect, will stick to it
-> Exactly! Of course the motor-torque is not magically de-/increasing, but the applied torque AFTER the drive-ratio is scaling with the drive-ratio, sorry for my "wald & wiesen denglish" here Just wanted to point out that I forgot to include this trade of speed<-to->applied-torque in my calc. Anyway was just going through my mind...
This is an artificial mass that is added to the mass of the load to be moved. So if for example the load to be moved of an axis is, say, 1kg and the rotor inertia is 68g.cmยฒ on a 16 tooth GT2 pulley (
r=0.51cm
), this will add about 260g of additional mass for the motor to move.
And sinceacceleration = force / mass
where force is given inN
and mass inkg
this is converted to kg (although this results inm/sยฒ
and I multiply the result by 1,000 to get the more commonmm/sยฒ
)-> Exactly! Of course the motor-torque is not magically de-/increasing, but the applied torque AFTER the drive-ratio is scaling with the drive-ratio, sorry for my "wald & wiesen denglish" here Just wanted to point out that I forgot to include this trade of speed<-to->applied-torque in my clac. Anyway was just going through my mind...
Two Germans writing in English about complex mechanical physics... what could possibly go wrong?
Also my calculator ignores speed constraints. It is solely about possible acceleration - if you can achieve high speeds with it is another topic.
r=0.51cm
and mass inkg
)Ah! So but in my case I have 2 synchro-belts per Axis = 4 in total, 2m long, 9mm wide, guess I have to add that mass also since that will not be neglectable in perspective to the rest mass
Yeah but this forum is great & thanks for helping me out anyway in whatever language - "math & physics are some sort of universal language" they told me
If you want to use the calculator just add it to the axis mass input field.
But seriously, have you weight them? How much could this be? 50g? These are all very lightweight objects.Yeah but this forum is great
I say that on every occasion. I learn something new every day here.
But seriously, have you weight them? How much could this be? 50g? These are all very lightweight objects....but 4 of them will be already - 200gr? - then, yeah will put some additional mass into that field... (confirmed in this "big" build it will be another ca. 150-200gr)
I think I will stop posting here and open a new post solely on "inertia" & "inertia-match" and all the calculation involved.
@lb By 50g I meant the total weight of all 4 belts... I have no clue if that is anywhere close to being realistic - I never had the idea of weighing my belts and pulleys.
Agreed, highly variable.
My comment was really in response to (paraphrased): "This can be calculated with just pully diameter". 6mm vs 9mm vs ??? comes into it as well.
So the input might need to be pulley weight & radius, belt width and length... maybe more...
"stupid" (maybe) question, while digging up new motor-alternatives: Those 2,4A, are they "per phase"? Or in total? I assume per phase.Because: Letยดs say I pick a motor that has 2,12A (1phase), what would be fine... then this motor will have 2 * 2,12A * 1/sqrt(2) -> = ca. 3A then on every two-phase step in total (with only 1,5A on each single phase of course).
Just because I have everything within arms reach (don't ask), here are the weights:
2m of 6mm Width GT2 belt: 16.11g
16T 6mm W, 5mm ID Aluminum Pulley: 2.92g
20T 6mm W, CR10 stock pulley: 6.10g
All of the above measured with an uncalibrated cheap Chinese scale, so just useful to get an idea.
